Cycle That Relief On Your HWH...or...? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2013, 12:03 PM   #1
biggles's Avatar
cycle that relief on your HWH...or...?
the burner control valve would have to get jammed open and kepp heating the water,but it takes all of 5 seconds with a bucket under that extended pipe to catch the blow off...
Tempstar heat pump won't initiate defrost cycle lgmccoy1 HVAC 14 12-08-2011 06:07 PM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
Pressure Relief Valve right after the Pressure Regulator Asathd Plumbing 0 07-03-2011 02:19 AM
Leaking Relief Valve Tobinator HVAC 1 01-16-2011 07:37 AM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
