Cutting Water Pipes To Washer - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-12-2012, 09:12 PM   #1
Rewards Points: 33
Cutting water pipes to washer
I plan to cut the water pipes to the washer in my house because I have two new cats that could possibly damage the pipes. The cat in the picture has went from 5 lbs to 8 lbs in about 5 weeks and can jump pretty high and so can his sister. Better to go to laundry mat I have decided.
To do this I have go into the crawlspace and cut the pipes. I could let plumber do this but I may be able to do this myself. Seems easy enough. Have been looking at a few youtube videos and googled the topic. Cold water is PVC and hot water is CPVC. So basically turn the water off, cut the pipe, and then I need to glue pipe with a fitting at the end of pipe where I will cut the pipe with a tool that cuts pipe or use a hacksaw. I was wondering do I need to chamfer the pipe ??? Is that necessary ??? Would like to do this myself. So next few days will decide to call plumber or do this myself.
steve3847 is offline   Reply With Quote
Old 09-12-2012, 09:16 PM   #2
I don't have cats so forgive me for my dumb question. How are your cats going to damage your pipes? Gnawing on them?
How about some spicy stuff like cayenne pepper near the pipes?
Lastly, what are you going to replace it with?
allthumbsdiy is offline   Reply With Quote
Old 09-12-2012, 09:23 PM   #3
Rewards Points: 14,306
This has to be a joke. That's one of the sillyest things I've ever heard of.
Unless you hanging cat toys from the pipes or rubbing cat nip on them, cats could care less about your pipes.
If you have old style rubber hoses replace them with stainless steel braded ones.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
ben's plumbing (09-13-2012), gregzoll (09-13-2012)
Old 09-12-2012, 09:24 PM   #4
Rewards Points: 47
New one on me too but cats can and do get themselves into trouble.
If by pipes. you mean the flex hoses connecting the washer to the house
piping, I'd spring for a high end set of braided ss covered ones. Let' see the
cats chew through them.
LeakyMike is offline   Reply With Quote
Old 09-12-2012, 09:54 PM   #5
Look, we've got 2 cats, pretty rambunctious, and yes they can jump pretty high too. But I've never given a moments thought to either of them damaging any of the washing machines water supplies.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
Old 09-12-2012, 09:56 PM   #6
Master Plumber
Javiles's Avatar
Rewards Points: 996
here is one idea on what to do with kitty
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following 2 Users Say Thank You to Javiles For This Useful Post:
Old 09-13-2012, 05:49 AM   #7
biggles's Avatar
box them in or cut the back lenght of PVC pipe and cover them with that
Old 09-13-2012, 06:24 PM   #8
Rewards Points: 582
I agree... has to be a joke..makes no sense...
Old 09-13-2012, 08:17 PM   #9
Rewards Points: 3,130
This entire thread is some kind of joke.
Old 09-13-2012, 09:09 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 904
If the cat chews a hole in the pipe, throw the feline into the dryer
Old 09-13-2012, 09:25 PM   #11
Rewards Points: 352
I love cats, I just can't eat a whole one
oops it appears I was wrong.
plumberinlaw is offline   Reply With Quote
Old 09-14-2012, 10:09 AM   #12
Rewards Points: 254
Close the door going into the laundry room??
pwgsx is offline   Reply With Quote
Old 09-14-2012, 07:00 PM   #13
Are your 2 cats Bengala tigers? Better replace your water pipes with black iron, and you'll be fine, and can still do you laundry at home. :-)
Pirulo is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Underground downspout drainage: Water standing in my brand new drainage pipes Airgibson Landscaping & Lawn Care 15 06-06-2012 07:41 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 08:10 AM
