Cutting PVC With No Space To Do It - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2011, 11:12 AM   #1
Cutting PVC with no space to do it
Greetings all,
I have a little bit of a problem I was hoping someone could help me out with... I am renovating a bathroom (complete gut and redo) and come to a PVC cutting problem. The original vanity did not have a back wall to it so the piping for the sink drain came directly out of the wall and to the sink.. The new vanity is like a piece of furniture with a roughly 1'w x 18" opening in the back for the pipe to go through. Problem here is the original pipe hits the non-movable shelf of the new vanity. So what I decided to do is to install new PVC. Here is where the fun starts. I will need to cap off the old 2", cut 4" just above the existing double Y pipe, install new Y just above it and connect to remaning vent pipe. The major problem is that the 4" pipe is in the middle (more or less) of two wall studs and it butts up almost complete against the drywall from the room behind. How can I get in there to cut that 4" pipe? No room to get in there with a hacksaw to cut it between the studs and if I go to cut it directly on, I will destroy the drywall for the other room.. Any and all suggestions would be GREATLY appreciated.
usas12gthr is offline   Reply With Quote
Old 05-20-2011, 11:47 AM   #2
Lightfoot's Avatar
Rewards Points: 272
maybe you could use a cable saw or wire saw as some call it.
http://www.harborfreight.com/cable-saw-98975.html
available just about anywhere.
Lightfoot is offline   Reply With Quote
The Following User Says Thank You to Lightfoot For This Useful Post:
usas12gthr (05-20-2011)
Old 05-20-2011, 11:49 AM   #3
I've heard, though never tried myself, of others using piano wire or something similar.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
Old 05-20-2011, 11:56 AM   #4
fabrk8r
fabrk8r's Avatar
Go to your local plumbing supply house and ask them for an "internal" 4" PVC cutter and chuck into your drill.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 05-20-2011, 02:00 PM   #5
Rewards Points: 352
Harbor Freight. multi tool 34 bucks
plumberinlaw is offline   Reply With Quote
Old 05-20-2011, 04:17 PM   #6
if the pipe is against the drywall you will need 1/4 inch clearance for the fitting and more if you use one of the rubber couplings. nylon string will cut the pipe tho. i was in the same situation once and was lucky enough to find a piece of nylon string outside on the site. wasn't easy but it worked. not the easiest place to have to cut .
The Following User Says Thank You to DannyT For This Useful Post:
usas12gthr (05-23-2011)
Old 05-20-2011, 08:44 PM   #7
Household Handyman
Rewards Points: 1,408
You can cut PVC with a piece of nylon string. Use it just like the thin wire saws you pay plenty for. You need only just enough room to get the piece of nylon string to go behind the PVC, make up two handles from most anything lying around, and saw away. There is a video on Youtube on how to do this.
The Following User Says Thank You to Thurman For This Useful Post:
Old 05-23-2011, 08:55 AM   #8
Nice looking Vette LF.. What year? 196? Do you have a larger pic you could post/send? I'm not much of a vette fan except for the late 50s throug 60s...
Crawl Space Issues / Too Many Layers of Floor jdmindy71 Flooring 1 12-31-2010 05:09 PM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
Cutting into wall to create a 24" tall by 15' wide crawlspace. Chesnut9 Building & Construction 4 11-21-2010 06:08 PM
Inadequate center support in tight crawl space 4just1don Building & Construction 5 09-28-2008 03:29 PM
Dedicated equipment space for subpanel? WoodworkerDave Electrical 11 09-14-2008 06:32 PM
