Old 03-09-2008, 01:18 PM   #1
Post
Cutting PVC drain/soil pipes
What's the best way to get nice straight cuts in drain and soil pvc pipes? I've tried with hack saws and never get a good perpendicular cut. Will using my miter saw (w/general purpose cross cut blade) prematurely dull the blade?
mw6263 is offline   Reply With Quote
Old 03-09-2008, 02:14 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
For larger PVC, I would go with a reciprocating saw and a little practice on scrap pipe.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-09-2008, 02:34 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Miter box with plain hand saw from Lennox
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-09-2008, 02:55 PM   #4
I have used a simple (and cheap) wooden miterbox with my PVC saw (handsaw). I think plastic dulls the blade lots quicker than wood. I did a prefab job up North and we did use a mitersaw for the repetitive cuts we had to make. Seemed to work well. I would advise a full face shield if using a power saw. Those chips hurt.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-09-2008, 03:28 PM   #5
Thanks.
I didn't think a regular hand saw would work with this material. I'll throw together a cheap miter box specific to the task.
Old 03-09-2008, 07:46 PM   #6
Send a message via AIM to Marlin
For 2" and smaller Ridgid makes a ratchet cutter which is excellent. Larger than that I use a reciprocating saw.
I've used a miter saw on occasion and it works fine. Just use a fine sharp blade and go slow.
Marlin is offline   Reply With Quote
Old 03-11-2008, 02:16 AM   #7
JDC
Plumbing Contractor
JDC's Avatar
a) sawzall
b) pvc handsaw
c) chop saw
Thats about all I use for PVC with my favorite being the chop saw. However, unless I'm making multiple cuts on 3" or larger, it just isnt worth dragging it out of the gangbox.
JDC is offline   Reply With Quote
Old 03-11-2008, 09:07 AM   #8
RippySkippy's Avatar
I'll do just about anything to get the cut made with a chop saw, make sure to debur after each cut.
I've cut stuff off under the floor with the cutoff wheel on a roto-zip...but man does that make a mess, handy but MESSY.
RippySkippy is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
Cutting Board DaveSteel Carpentry 1 02-21-2008 10:38 AM
Leaking around joint of PVC pipes in attic themadcatter HVAC 10 12-18-2007 10:29 AM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 01:06 PM
