Cutting Out A Concrete Structural Basement Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-26-2010, 10:32 PM   #1
cutting out a concrete structural basement floor
How do you run plumbing in a basement with a structural steel floor with concrete.
Marc Bourgeois is offline   Reply With Quote
Old 08-27-2010, 05:37 AM   #2
Not sure what you have, is it a residential or commercial?? I can explain how to cut steel or concrete, each uses a different type of blade.
Old 08-27-2010, 09:10 AM   #3
Rewards Points: 558
You can rent a dry concrete saw with a diamond blade and make sure you:
1) Cover everything as this saw will make a lot of dust.
2) Wear a respirator.
3) Measure and mark the line(s) where you will cut. This can be done with a marker or chalk line.
4) Cut in the same direction if you need to make another pass to complete the cut.
5) Chip away the concrete area that has been cut.
6) Consult a structural engineer before any cutting is done.
As per cutting holes in the beam, I am presuming you will be cutting into the web portion of the beam as this can be done and the following can be used:
1) You can use a torch or a magnetic slugger cutter.
2) Before you attempt to do this you should consult and get approval by a structural engineer or competent architect as this cutting/drilling will weaken the beam and may require welding stiffeners to either side of the holes in order to keep the beams integrity.
3) All holes should be cut by a licensed welder unless the purposes of the holes are used to fasten material.
epson is offline   Reply With Quote
Old 08-29-2010, 02:23 PM   #4
Rewards Points: 150
Like the o.p. said you have to explain exactly what you are refering to.
braindead is offline   Reply With Quote
cutting my basement floor jeffm2 Plumbing 5 04-23-2010 01:46 PM
Basement concrete floor repair estimate ControlTech Building & Construction 1 04-10-2010 07:28 AM
Concrete Basement floor Fill & Level Crispy Building & Construction 4 11-06-2009 05:39 PM
Ceramic floor tile on concrete basement floor w/toilet pedestal amp2oo1 Flooring 1 10-05-2009 07:31 AM
Basement floor over concrete slab Straightgrain Flooring 9 03-09-2009 12:38 PM
