Old 06-18-2010, 05:26 PM   #1
Cutting the main pipe off my well to reroute?
I'm going to be installing an irrigation system at my residence and I'm using an existing artesian well for my water supply. I need to cut the pipe off that is coming up out of the ground so I can reroute it to my pump to start setting up the sprinkler system.
How do I manage this?
mattsonberg is offline   Reply With Quote
Old 06-18-2010, 06:09 PM   #2
I hate to destroy infrastructure so I would go with a hose and hose clamps before I go ahead and cut that pipe.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 06-18-2010, 08:36 PM   #3
I'm not sure what you mean by using a hose and hose clamps. Can you be more specific?
OK, I see what the hose clamp is, but how does it help you when you're trying to attach a new piece of piping to the main line? I have no way of shutting off the flow of water. I'll be cutting the pipe below ground BEFORE the shutoff valves that currently exist. Maybe I wasn't clear enough about that.
Old 06-18-2010, 10:24 PM   #4
I meant to say, don't cut the pipe below ground!
Attach what you want (a tee, a hose, etc.) to the well pipe currently above ground, preferably after the shutoffs.
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
Cutting Hydropex pipe Cecosugi HVAC 11 12-11-2009 10:02 AM
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 1 07-12-2009 11:46 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
