-   -   Cutting the main pipe off my well to reroute? (http://www.diychatroom.com/f7/cutting-main-pipe-off-my-well-reroute-74078/)
mattsonberg 06-18-2010 04:26 PM
I'm going to be installing an irrigation system at my residence and I'm using an existing artesian well for my water supply. I need to cut the pipe off that is coming up out of the ground so I can reroute it to my pump to start setting up the sprinkler system.
How do I manage this?
AllanJ 06-18-2010 05:09 PM
I hate to destroy infrastructure so I would go with a hose and hose clamps before I go ahead and cut that pipe.
mattsonberg 06-18-2010 07:36 PM
I'm not sure what you mean by using a hose and hose clamps. Can you be more specific?
OK, I see what the hose clamp is, but how does it help you when you're trying to attach a new piece of piping to the main line? I have no way of shutting off the flow of water. I'll be cutting the pipe below ground BEFORE the shutoff valves that currently exist. Maybe I wasn't clear enough about that.
AllanJ 06-18-2010 09:24 PM
I meant to say, don't cut the pipe below ground!
Attach what you want (a tee, a hose, etc.) to the well pipe currently above ground, preferably after the shutoffs.
