Cutting Into Cast-Iron Waste Pipe. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2010, 10:10 AM   #1
dOe
Boston, MA.
Question
Cutting into Cast-Iron waste pipe.
I m in process of finishing my basement and adding a Saniflo up-flush system. The waste pipe is going to travel over to my existing 4" cast-iron waste pipe.
Now, what I was thinking of doing is taking a Sawz-all to the pipe an cutting out a piece to retrofit a PVC Y-pipe. Is this an acceptable practice? Any thing I need to know or do prior to cutting the pipe with a Sawz-all?
The pipe alread has a 1-1/2" drain that is used fr the washer which is PVC. Could tha be used for the SaniFlo, or is 1-1/2" to small for solid waste?
dOe is offline   Reply With Quote
Old 03-29-2010, 02:35 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You can cut cast iron with a sawzall with metal cutting blade or a snap cutter made for the purpose, but whatever you use to cut it, make certain that you have braced the cast iron from dropping down when you cut it.
All of the weight of the cast iron above the cut will be on it. Use 2x4 bracing if necessary.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-29-2010, 02:53 PM   #3
It is better to cut in a cast iron wye then transition to pvc....like Mike said make sure the pipe is supported before you cut it.
SuperPlumberGuy is offline   Reply With Quote
Old 03-29-2010, 04:04 PM   #4
dOe
Boston, MA.
Thanks!
Usually though don't stacks have braces clamped on them between floors?
Old 03-29-2010, 07:09 PM   #5
DIY staff
Rewards Points: 7,174
I know a plumber who used to think that all vents were anchored--(they should be)
He's short two fingers on his left hand now.
Always be cautious of other peoples work--Mike---
Tags
basement bathroom , cast iron , plumbers , plumbing
cast iron drain pipe? sharp Plumbing 3 10-14-2009 12:52 PM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 11:48 AM
Cutting Iron Drain Pipe jonathan03 Plumbing 12 01-31-2009 10:33 PM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 10:43 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
