Cutting A Hole In Basement Floor For Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2011, 11:28 AM   #1
cutting a hole in basement floor for toilet
how do I know where to cute hole in basement floor to install rough plumbing for a toilet and a shower?
Is it better to use a concrete saw or a jack hammer?
lrkramer001 is offline   Reply With Quote
Old 01-15-2011, 01:30 PM   #2
Homerepairguy's Avatar
Rewards Points: 998
Determine where you want your toilet and shower to be and hire a plumber to advise you about the waste run with slope to meet code. You will also have to cut a channel through the concrete to lay the waste pipe to where the plumber connects to the existing waste line.
When I broke the concrete in our carport's floor to run the waste pipe for an addition, I used a jack hammer. I figured that a concrete saw would need a diamond blade and create a ton of dust. If there are any rebars in the concrete, then additional problems using a saw.
Don't forget that you will need to install a vent pipe which the plumber can also advise you on how best to run it. It "may" need to be vented through the roof.
HRG
Homerepairguy is offline   Reply With Quote
Can someone tell me what this hole in my basement is(pics inculded) vande060 Building & Construction 10 01-04-2011 09:31 PM
Cutting Vent Hole in Roof How To Wanted wildbilly Plumbing 17 06-02-2010 04:35 AM
cutting my basement floor jeffm2 Plumbing 5 04-23-2010 01:46 PM
Cutting stair stringers for OLD basement steps 4just1don Building & Construction 1 08-11-2009 06:21 AM
Cutting a hole in stone foundation casualty x Building & Construction 2 01-11-2008 06:28 AM
