Cutting Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2012, 08:12 PM   #16
Rewards Points: 1,214
Shut gas off at meter, vent piping real good, use 2 pipe wrenches to remove fittings and pipe back to where the pipe you want to remove comes out of the main, plug or cap it there using the proper pipe dope, leak check with proper gage and soap bubbles, turn main back on, relight all pilots.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 10-03-2012, 08:38 PM   #17
Rewards Points: 558
Originally Posted by skinut2234 View Post
thanks squished-! I was actually going to use a lighter
if you did you'd look like this:
epson is offline   Reply With Quote
Old 10-03-2012, 09:55 PM   #18
Rewards Points: 582
shut off at meter vent line start cutting ..hacksaw..sawzall ..pipe wrenchs they all work....after repairs....pressure test, soap fittings... dial test it all works...question is are you certified to work on gas lines??????? you should be ..gas company would not be happy...neither would your family if something happens....just my opinion....be careful......think about it...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
COLDIRON (10-04-2012)
Line to line load on a MWBC? rjniles Electrical 13 12-09-2011 08:09 AM
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 09:09 AM
sewer line Master Brian Plumbing 3 05-25-2009 01:53 AM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
