#1 |
cutting gas line
in our new kitchen layout- we no longer need the gas line that went up thru the attic that fed the old oven. I can trace it back to the basement and cap it off there (or put a valve)- I would shut off the house main gas- let it bleed for a bit- etc- Best way to cut I'm guessing is a hacksaw? I'd be a little weary about using a sawzall....
#2 |
DIY Enthusiast
cutting gas line
Why cut it? A few pipe wrenches at the joints and twist.
#3 | |
cutting gas lineQuote:
#4 |
cutting gas line |
#5 |
cutting gas line
yea- I was just afraid I would twist something else loose in the line somewhere.....
#6 |
cutting gas line
We don't have many details of the pipe lay out so unless there is a union somewhere in the length you are wanting to abandon you will need to unscrew every joint until you get to the end where you want to cap it off. Otherwise cut, unscrew the stub and cap.
#7 | |
Experienced
Mark
When its all said and done there is usually more said than done To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to Jackofall1 For This Useful Post: | sublime2 (10-02-2012) |
#8 | |
What I did was to apply 2 masking tape sections for 2 joints prior to the section I was working on and drew a straight line. That way, if I accidentally disturbed other pipes, I would see it right away. I also do the soap bubble test to be sure. Good luck |
#9 |
cutting gas line
Sawzall. Wouldn't even think twice about it after the gas was shut off and bled out.
#10 |
cutting gas line
is there any "test" that can be done to insure all the gas is out of the line (or do you never really get all the gas out 100% of the time)
#11 |
cutting gas line |
#12 | |
otherwise, i believe pros use inert nitrogen gas to flush out the pipes. |
#13 |
cutting gas line
thanks squished-! I was actually going to use a lighter
#14 |
JOATMON
cutting gas line
Still at a loss as to why you want to cut the line....it's pretty hard to cap a gas line that is not threaded.
I would just remove the pipes one at a time....then you end up with some spare pipe you can use later.
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#15 |
cutting gas line
" I knew a guy who used to check his pipe jobs like that after he was finished". Not Kidding.
No Warranty Means- If it breaks in half you get to keep both halves. |
| The Following User Says Thank You to COLDIRON For This Useful Post: | ben's plumbing (10-03-2012) |
| Display Modes | |
| Line to line load on a MWBC? | rjniles | Electrical | 13 | 12-09-2011 08:09 AM |
| New ICe maker line causes ice to taste like rubber | speedster1 | Plumbing | 5 | 06-27-2010 09:09 AM |
| sewer line | Master Brian | Plumbing | 3 | 05-25-2009 01:53 AM |
| Add natural gas line | Tukeeman | Plumbing | 11 | 12-01-2008 08:53 AM |
| electric line and gas line | couch potatoe | Electrical | 17 | 09-30-2008 11:43 PM |
