Cutting A Fire Hydrant Down To Size - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2011, 09:08 AM   #16
Originally Posted by WillK View Post
Plasma cutter would be better than torch...
Better how?
Pistol Pete is offline   Reply With Quote
Old 03-15-2011, 09:48 PM   #17
Rewards Points: 152
I'll second the gas cutoff saw idea.
Just need a metal cutting wheel and you'll be through in no time.
burnt03 is offline   Reply With Quote
The Following User Says Thank You to burnt03 For This Useful Post:
braindead (03-15-2011)
Old 03-15-2011, 10:22 PM   #18
Ravenworks's Avatar
That is all we use,how ever you have the wrong blade,you need a Bi-metal blade
Ravenworks is offline   Reply With Quote
Old 03-16-2011, 07:15 AM   #19
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,030
Better how?
Ayuh,... I'm not sure about a plasma cutter, 'n cast iron,...
But,...
I Do know that Ox/ Ac Torches will NOT cut cast iron....
Old 03-16-2011, 08:15 AM   #20
I ask the impossible!
Rewards Points: 660
With an oxy/acetylene torch, and I'm not sure I've used it for cast iron but I've done 1" steel and bolts, you heat the metal to its melting point, then you squeeze the handle and it pretty much is blowing oxygen. It doesn't work for stainless steel or aluminum, but that's just a side note. The edge that is left behind is metal that melted and then cooled without falling away, so while you're not going to be concerned with the changes to the structural integrity of the metal in this case, the cut wouldn't tend to be as clean as a plasma cutter (or the various saw options).
The plasma cutter is pretty likely something that a welding shop is going to have and like I said, it will make a cleaner cut.
If you were to need to get equipment, you'd probably get a cutting torch set and tanks cheaper than a plasma cutter.
The images below show metal cut with a torch (the image with the black background) and a cast iron piece cut with a plasma cutter (the L shaped piece) from images I found searching the internet.
WillK is offline   Reply With Quote
Old 03-17-2011, 09:51 PM   #21
Just use a zip cut disc on an angle grinder, it will cut through any metal quickly and the discs are reasonably priced.
Dougtheplumber is offline   Reply With Quote
Old 03-21-2011, 01:57 AM   #22
JourneymanSteelFabricator
I would agree with the ZipCut. They cut through almost anything. Wear gloves and safety glasses or face-shield. Plasmas do not like to cut through cast. Not sure if the hydrant is case steel or cast iron. Most likely cast steel as they need to be threaded for the hose couplings.
The gas cut off saws are good for some uses but they tend to kick back. I personally would not recommend the gas saw unless you can clamp that sucker down well.
BCanuck is offline   Reply With Quote
Old 03-21-2011, 04:01 PM   #23
WDR
hose connection
I not sure how most of them are but I have seen ones that have brass threaded fittings for the hoses to connect. I am thinking because steel threads would get pitted and rusty making it hard to screw the hose on. I know this is not at all related to cutting the hydrant but I thought I would mention it.
WDR is offline   Reply With Quote
Fire Pit on Gravel unclenanoose Landscaping & Lawn Care 8 10-29-2010 07:48 PM
Extension cord fire Ultrarunner2017 General DIY Discussions 8 07-04-2010 10:52 AM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 08:13 PM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 05:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
