Cutting A Fire Hydrant Down To Size - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2011, 07:25 PM   #1
Question
Hey all, i have a question that is... slight odd
I came across an old fire hydrant recently. (legally, i assure you.) There is two, three feet of cast iron pipe under the visible hydrant. It is about 7/8", 1" thick, and about a foot in diameter.
I want to remove this pipe, leaving only the visible segment.
what tool is the most effective for this? also, i would like to get the cut as snug up to the slight lip that is on the bottom of the visible hydrant.
Hope that makes sense, ask me about anything that doesn't! thanks for any information you can provide!
IdleWild is offline   Reply With Quote
Old 03-13-2011, 07:46 PM   #2
the Musigician
DangerMouse's Avatar
A sawzall with a few metal cutting blades?
DM
Old 03-13-2011, 08:02 PM   #3
Buying the first round
LIHR's Avatar
If it's a traffic break-away type use a hammer
http://www.ranteso.com/
LIHR is offline   Reply With Quote
Old 03-13-2011, 08:09 PM   #4
Learning by Doing
Leah Frances's Avatar
Pics! One of my husband's college roommates had one (also through legitimate sources) his dad painted red. It was gorgeous.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-13-2011, 08:34 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 820
Not sure what yours looks like but I'd say use a big grinder or demo saw with a metal cut off blade. The hydrant pipe is probably made of ductile iron.
The Following User Says Thank You to TheEplumber For This Useful Post:
braindead (03-15-2011)
Old 03-13-2011, 11:17 PM   #6
thanks for the input, guys! i'll check if it's a breakaway... that'd make this whole thing really easy.
I considered the sawzall, but i think it'd just be time consuming. thought maybe there's a faster way to do this. If i try it and it fails, well, i guess i'll go down to my local hardware store and rent something with a little more... beef
and sorry, i don't have any pics to post! it's currently under a couple feet of snow in my backyard. thought i'd get some ideas in mind before spring rolls around (which should be about now, but North Dakota is always a little late in that regard) so i can jump on it once snow melts. I already picked up some primer and fire engine red paint, ready to go! i was hoping to make it an interior decoration as opposed to something in my backyard, thought it'd be pretty cool!
Old 03-13-2011, 11:28 PM   #7
Plumber
Rewards Points: 820
Better keep it indoors when finished or every dog in the neighborhood will be in your yard
Old 03-13-2011, 11:47 PM   #8
Rewards Points: 1,538
I would use a saw, I was thinking of a circular diamond studded pavement saw if you can rent one of those.
I would not use a chain style cast iron pipe cutter or a hammer, too much of a risk of shattering the bottom of the hydrant.
Old 03-14-2011, 07:28 AM   #9
WDR
In my area they are always bolted to the pipe so if it is made like that you could just un bolt it. There would still be a shaft in the middle that you might have to cut. I believe this is the break-away type mentiond erlier.
WDR is offline   Reply With Quote
Old 03-14-2011, 09:00 AM   #10
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,638
Ayuh,... I agree, Except, diamond blades are for stone,...
Use a carborundum blade for Metal...
Old 03-14-2011, 12:03 PM   #11
Rewards Points: 382
Are you in a fire district? If so, you probably cannot put it in a visible place, as that would be against the IFC
fireguy is offline   Reply With Quote
Old 03-14-2011, 03:07 PM   #12
yeah that's also why i wanted it in my basement. no potential problems there. otherwise it woulda been my backyard, which isn't visible from the street.
I'll look into local tool rentals more, see who offers a pavement saw, and if there are multiple who offers it the cheapest.
thanks for the info!
Old 03-14-2011, 08:34 PM   #13
Perhaps a local welding shop could cut it with a torch. I have no idea if that would be cheaper or more expensive than renting a saw, but it sure would be quicker.
Pistol Pete is offline   Reply With Quote
Old 03-14-2011, 10:07 PM   #14
I ask the impossible!
Rewards Points: 704
Plasma cutter would be better than torch...
A soil pipe cutter won't cut that?
WillK is offline   Reply With Quote
Old 03-14-2011, 10:23 PM   #15
peaked at birth
If it is ductile iron, you will burn out your sawzall regardless of blades & no snapper will touch it. I use an abrasive cut off blade on a 14" electric or gas operated saw. Cuts like butter, is fast and is the cheapest way too. Totally rentable stuff. You could use a wrap of det cord.
analyst is offline   Reply With Quote
The Following User Says Thank You to analyst For This Useful Post:
Fire Pit on Gravel unclenanoose Landscaping & Lawn Care 8 10-29-2010 07:48 PM
Extension cord fire Ultrarunner2017 General DIY Discussions 8 07-04-2010 10:52 AM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 08:13 PM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 05:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
