Cutting Down 1" NPT Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-22-2010, 09:31 AM   #1
Rewards Points: 270
Cutting down 1" NPT drain pipe
We are swapping out a wall hung sink for a pedistal and the existing horizontal drain pipe for the old sink sticks out too far from the wall , not allowing the pedistal to get close enough to the wall.
Also the threads are nearly gone... not sure what happened but they are all corroded and half missing! The rest of the pipe seems solid though.
The pipe is 1" iron pipe (determined by measuring OD of 1.9" exactly)
Can I just cut off the end to proper length and put some kind of slip compression fitting on it?
pcampbell is offline   Reply With Quote
Old 07-22-2010, 01:16 PM   #2
Rewards Points: 352
Google Fernco or mission bond
plumberinlaw is offline   Reply With Quote
Old 07-23-2010, 05:53 AM   #3
Rewards Points: 270
easy enough - thank you.
Old 07-23-2010, 09:20 AM   #4
The pipe enters the wall and then screws into a tee.You can easily unscrew the pipe and replace with the proper length. Will look better than a fitting in the line.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Sink drain for new sink. Can't get to plain pipe. rogersmithiii Plumbing 2 07-10-2009 10:24 AM
Vent requirement for laundry washer drain pipe WaldenL Plumbing 9 01-12-2009 07:11 PM
Joining ABS p-trap under shower to C.I. drain pipe warriorfox Plumbing 4 01-01-2009 01:29 AM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 08:32 PM
