Cutting Clay Tile Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2009, 09:49 PM   #1
Rewards Points: 150
cutting clay tile pipe
Any tips for cutting the old clay tile pipes?
I'm replacing my under-slab waste line all the way to the wall with PVC, but can't risk it cracking if I cut it wrong.
johnnyboy is offline   Reply With Quote
Old 02-16-2009, 10:16 PM   #2
Registered User
Termite's Avatar
Not sure what a pro would do, but I'm thinking an angle grinder with a masonry blade would do an ok job.
Old 02-16-2009, 10:43 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,058
Ayuh,...
Or a Roto-zip with a cutting wheel,...
Depends on how much of it you can daylight....
Old 02-17-2009, 12:10 PM   #4
plumbing contractor
PLUMBINGITALL's Avatar
Angle grinder with a dimound tip bit
PLUMBINGITALL is offline   Reply With Quote
Old 02-17-2009, 06:12 PM   #5
Chain cutters
Plumber44 is offline   Reply With Quote
Old 02-17-2009, 06:37 PM   #6
chain cutter works the beat . you can rent for about 30.00
metx is offline   Reply With Quote
Andalusa Clay tile from Honduras Tom Roofing/Siding 3 06-29-2013 08:39 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Cutting Iron Drain Pipe jonathan03 Plumbing 12 01-31-2009 09:33 PM
Cutting Narrow Tile Pieces MrBill_DIY Remodeling 2 08-17-2008 12:33 AM
Cutting Tile rookie1 Remodeling 9 10-22-2007 04:25 PM
