Cutting Cast Iron - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2011, 07:01 PM   #1
J&N
Cutting Cast Iron
I am about to remodel my bathroom and I need to cut up the cast iron tub to get it out of the house. What sawzall blade do I need to get the job done?
J&N is offline   Reply With Quote
Old 10-14-2011, 07:07 PM   #2
jules4's Avatar
Easiest way to break up a cast iron tub is with a sledge hammer - cast iron is brittle. (cover tub with a blanket first, it makes a huge mess.)
Edited to add: for less mess score lines into the tub with a grinder and then sledge it, it should snap along the lines.
Email: the to-do list anyone in the world can add items too.
jules4 is offline   Reply With Quote
Old 10-14-2011, 07:10 PM   #3
DIY staff
Rewards Points: 7,174
---You will be cracking it apart with a sledge hammer--
Goggles and gloves--start on the inside and hit it in the same spot with steady moderate blows--soon enough a crack will start---follow the crack with more steady moderate blows and in no time the tub will be in manageable sized chunks.
Old 10-15-2011, 05:45 PM   #4
J&N
Tub reverberations!!!
I was hoping to avoid sending shock waves through the rest of the (old) house causing issues in other rooms. Is there a sawzall blade I can use to get the job done instead of the heavy handed approach?
Old 10-15-2011, 05:59 PM   #5
DIY staff
Yes----Milwaukee makes a cast iron cutting blade---
Have you tried to pull it out in one piece? Using a helper I can usually get them out whole and down to the curb.
You are right to worry about 'collateral damage'--it is a very real possibility.
Old 10-15-2011, 06:10 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 780
Don't even think about it. You can't buy enough blabes and you will prolly burn up the sawzall
If you don't want to use a sledge hammer, try a grinder
Old 10-15-2011, 08:20 PM   #7
TheEPlumber is correct: you'll spend a fortune in blades, and probably kill your sawzall. Either take it out in one piece, or bust it up.
Ishmael is offline   Reply With Quote
Old 10-15-2011, 08:45 PM   #8
Mark Potter's Avatar
Rewards Points: 150
Tungsten sawzall bade 1 blade! cut that sucker in 4 sections.
Mark Potter is offline   Reply With Quote
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 10 01-22-2014 07:55 PM
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
