Old 02-19-2013, 10:45 AM   #1
cut off pipes toilet
Hi everybody,
In those pics you can see the pipes that I have in the basement to install a new bathroom, but I don't want a new bathroom in the basement because It's tiny, so how should I do to cut off those pipes. I am thinking for the vent pipe I will make a column but what about for the other one??
Is it possible leave the pipe under the floor and not under the cement (and put for example something to cover the pipe). I was wondering if the next owner wants to make the washroom they only need to remove the square covering the pipe
thks
pavlito24 is offline   Reply With Quote
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 10:58 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Toilet location has become a bit of a problem BOUTYM Plumbing 13 10-10-2011 12:19 PM
New toilet base doesn't line-up to floor bolts wwsteel7 Plumbing 9 11-25-2010 11:02 AM
Where to Move this Toilet? estburke Plumbing 8 10-11-2010 12:52 AM
