Cut A Hole In A SS Sink? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-27-2013, 07:59 PM   #1
MT Stringer's Avatar
Rewards Points: 240
Cut a hole in a SS sink?
Is there anyway to cut a hole in a stainless steel sink? I don't have a clue.
New faucet has a soap dispenser. nother hole would be great.
Thanks.
Mike
MT Stringer is offline   Reply With Quote
Old 08-27-2013, 08:14 PM   #2
Rewards Points: 706
Thanks.
Mike
In my experience a hole saw at a low ( subjective ) rpm would do the job.
SeniorSitizen is offline   Reply With Quote
Old 08-27-2013, 08:17 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
Use a electricians knock out punch
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
COLDIRON (08-29-2013), oh'mike (08-27-2013), Peppe1019 (08-27-2013)
Old 08-27-2013, 09:07 PM   #4
Rewards Points: 240
OK. Thanks. I will consider the options. Might not do anything.
Old 08-28-2013, 12:07 AM   #5
I've also used a step drill bit with great success.
VIPlumber is offline   Reply With Quote
The Following 2 Users Say Thank You to VIPlumber For This Useful Post:
MT Stringer (08-28-2013), TheEplumber (08-28-2013)
Old 08-28-2013, 08:14 AM   #6
Rewards Points: 13,296
All good suggestions.
If you choose a hole saw make it a Bimetal not a carbon steel.
Those step drills are nice, just a little expensive for a good one. One drill will make a whole range of hole sizes and leave very little burr.
Old 08-28-2013, 11:21 AM   #7
Rewards Points: 3,130
I've always heard those things called versabits or cheater bits. Nobody where I worked would ever use one.
Old 08-28-2013, 11:22 AM   #8
I've always heard those things called versabits or cheater bits. Nobody where I worked would ever use one. The QA inspector would've eaten them alive.
Old 08-28-2013, 06:12 PM   #9
Any reason why? Versi Bit is just a brand name.
Step Drill is the proper name.
Old 08-28-2013, 07:36 PM   #10
DIY staff
Rewards Points: 7,174
My electrician uses one of those-----they seem to work well and rarher quickly in a steel electrical box.
I've never tried one---
Old 08-28-2013, 07:47 PM   #11
Plumber
Rewards Points: 452
For a one time application like we're addressing, I'd probably opt for the uni-bit
A person can purchase a high quality one easily.
But the punch may be harder to come by and cost more as well- perhaps a rental yard will have one.
I have tried a hole saw before- I got very upset with the lack of progress.....
Old 08-28-2013, 10:00 PM   #12
Master Plumber
Javiles's Avatar
Rewards Points: 990
Publix isle 7
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 08-28-2013, 10:00 PM   #13
Rewards Points: 240
Thanks for your thoughts.
I figured with a hole saw, I would probably booger up the sink when the bit gets away from me.
The knock out is too costly for a one time operation.
I'll think about the uni bit. When I asked my wife about where we could mount the soap dispenser, she said just forget it for now. Whew! :-)
The Following 2 Users Say Thank You to MT Stringer For This Useful Post:
oh'mike (08-30-2013), VIPlumber (08-28-2013)
Old 08-29-2013, 08:53 AM   #14
Bill Kearney
Rewards Points: 1,174
If you're talking about cutting into the deck of a drop-in sink, yeah, a hole saw would definitely make a mess of it if it got away from you. Bear in mind that most soap dispensers come with an escutcheon around them that would hide a bit of the hole's edges, that and provide a base of a washer to make a seal. So a decent quality, new, step-bit should be able to do the job. Just do yourself a favor and tape off the area so if any slight slips won't leave marks.
wkearney99 is offline   Reply With Quote
Old 08-29-2013, 09:48 AM   #15
Most of my working life was spent in the nuclear power industry (operations and maintenance). You cannot imagine the stringency of the QA requirements at a nuclear plant - makes NASA look like rank amateurs. Besides step drills, some common hand tools such as crescent wrenches and Leathermen were usually prohibited anywhere on the site. Violation meant termination.
Delta / Moen faucet sink hole size minimums nthdegreeburns Plumbing 8 07-24-2012 09:52 PM
layout and floor hole placement for kit sink firsthomereno Plumbing 2 04-27-2012 06:25 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 07:24 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
