-   -   Cut a hole in a SS sink? (http://www.diychatroom.com/f7/cut-hole-ss-sink-186064/)
MT Stringer 08-27-2013 07:59 PM
Is there anyway to cut a hole in a stainless steel sink? I don't have a clue.
New faucet has a soap dispenser. nother hole would be great.
Thanks.
Mike
SeniorSitizen 08-27-2013 08:14 PM
Thanks.
Mike
In my experience a hole saw at a low ( subjective ) rpm would do the job.
TheEplumber 08-27-2013 08:17 PM
199 Attachment(s)
Use a electricians knock out punch
MT Stringer 08-27-2013 09:07 PM
OK. Thanks. I will consider the options. Might not do anything.
VIPlumber 08-28-2013 12:07 AM
I've also used a step drill bit with great success.
http://img.directindustry.com/images...11-2788007.jpg
joecaption 08-28-2013 08:14 AM
All good suggestions.
If you choose a hole saw make it a Bimetal not a carbon steel.
Those step drills are nice, just a little expensive for a good one. One drill will make a whole range of hole sizes and leave very little burr.
md2lgyk 08-28-2013 11:21 AM
I've always heard those things called versabits or cheater bits. Nobody where I worked would ever use one.
md2lgyk 08-28-2013 11:22 AM
I've always heard those things called versabits or cheater bits. Nobody where I worked would ever use one. The QA inspector would've eaten them alive.
joecaption 08-28-2013 06:12 PM
Any reason why? Versi Bit is just a brand name.
Step Drill is the proper name.
oh'mike 08-28-2013 07:36 PM
My electrician uses one of those-----they seem to work well and rarher quickly in a steel electrical box.
I've never tried one---
TheEplumber 08-28-2013 07:47 PM
199 Attachment(s)
For a one time application like we're addressing, I'd probably opt for the uni-bit
A person can purchase a high quality one easily.
But the punch may be harder to come by and cost more as well- perhaps a rental yard will have one.
I have tried a hole saw before- I got very upset with the lack of progress.....
Javiles 08-28-2013 10:00 PM
1 Attachment(s)
Publix isle 7
MT Stringer 08-28-2013 10:00 PM
Thanks for your thoughts.
I figured with a hole saw, I would probably booger up the sink when the bit gets away from me.
The knock out is too costly for a one time operation.
I'll think about the uni bit. When I asked my wife about where we could mount the soap dispenser, she said just forget it for now. Whew! :-)
wkearney99 08-29-2013 08:53 AM
If you're talking about cutting into the deck of a drop-in sink, yeah, a hole saw would definitely make a mess of it if it got away from you. Bear in mind that most soap dispensers come with an escutcheon around them that would hide a bit of the hole's edges, that and provide a base of a washer to make a seal. So a decent quality, new, step-bit should be able to do the job. Just do yourself a favor and tape off the area so if any slight slips won't leave marks.
md2lgyk 08-29-2013 09:48 AM
Most of my working life was spent in the nuclear power industry (operations and maintenance). You cannot imagine the stringency of the QA requirements at a nuclear plant - makes NASA look like rank amateurs. Besides step drills, some common hand tools such as crescent wrenches and Leathermen were usually prohibited anywhere on the site. Violation meant termination.
