Old 09-19-2011, 12:29 PM   #1
Cut Galvanized pipe to PEX connection question.
How do I Connect PEX to a cut end of galvanized pipe in an underground instalation?
rkerwood is offline   Reply With Quote
Old 09-19-2011, 11:11 PM   #2
Doing it myself
Alan's Avatar
You don't. Not without rethreading the cut end of galvanized anyway.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plumber666 (09-19-2011)
Old 09-19-2011, 11:35 PM   #3
Plumb or Die!
Best to eliminate the galvanized completely, a lot of areas they make you do that. If its gotta stay, keep digging back till you find a threaded connection and adapt from there. Or like Alan said, rent a hand threader and thread it in place.
plumber666 is offline   Reply With Quote
Water softener connection question Aldyrin Plumbing 1 09-22-2010 10:30 PM
Air tool/pvc pipe connection Ronnie1a Tools 1 11-25-2009 02:51 PM
P Trap & Galvanized Pipe Catchinyellows Plumbing 4 11-11-2008 11:22 AM
Water Galvanized pipe to Pex sssalas Plumbing 6 09-24-2008 03:47 PM
burying galvanized steel pipe amakarevic Plumbing 9 08-19-2008 11:37 AM
