Custom Made Plumbing Connections - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2011, 10:07 PM   #1
Custom made plumbing connections
who can I approach to make simple customised plumbing connections?
shyam is offline   Reply With Quote
Old 03-15-2011, 10:28 PM   #2
What kind of 'connections' are you talking about? All plumbing pipe has to be connected at some point and rarely are there situations where a 'custom' connection has to be made.
VIPlumber is offline   Reply With Quote
Old 03-15-2011, 11:12 PM   #3
I have seen a Video of a kit that converts a toilet to a bidet. There is a modified inlet vlave just below the toilet tank with an out let that feeds the bidet.
If you google Bidet and biffy youcan see it.
How does one get such products manufactured or ordered?
Old 03-15-2011, 11:31 PM   #4
Water Treatment
Rewards Points: 900
Most likely you can find that kit if you look for it or you can buy a toilet that does what you are looking for or spend a ton of money coming up with some thing that might work..
Akpsdvan is offline   Reply With Quote
Old 03-15-2011, 11:41 PM   #5
there are a lot of bidet toilet seats available out there. found this one on amazon in 5 sec. http://www.amazon.com/Brondell-S1000.../dp/B0045UB9GK. they all require a gfci outlet, and some require a hot water angle stop, but they're really easy to install (doesn't require any custom made fittings )
the_man is offline   Reply With Quote
Old 03-16-2011, 12:34 AM   #6
I am not inquiring the electrical part. I am inquiring about the tee below the tank that feeds both the tank as well as the water to the bidet.
This kit that can be added to exsisting toilets run about $50.
They are easy to fit but this part is not available in retail plumbing stores.
In other words-- If I had this idea, how would I get a manufacture to make such parts for me?
Old 03-16-2011, 08:08 AM   #7
Plumb or Die!
Patent the part, then go to Brass Craft or another manufacturer with your idea. Then watch the money roll in.
plumber666 is offline   Reply With Quote
The Following 2 Users Say Thank You to plumber666 For This Useful Post:
shyam (03-16-2011), VIPlumber (03-16-2011)
Old 03-16-2011, 08:51 AM   #8
So then contact this manufacturer and they should be able to help you.
The Following User Says Thank You to VIPlumber For This Useful Post:
shyam (03-16-2011)
Bathroom remodel, sink plumbing dschmid Plumbing 3 02-03-2011 08:32 PM
Basement Bathroom - plumbing thoughts (pics) rkerns Plumbing 1 01-12-2011 04:14 PM
Demo'd Half-Bath, Pics Attached, Any Plumbing? 99altrade Plumbing 12 12-23-2010 09:48 AM
Custom Shower Pan Plumbing Questions aumanpj Plumbing 6 02-12-2010 06:30 PM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 11:14 AM
