Custom Gas Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-09-2009, 06:53 PM   #1
Custom gas pipe
I have a quick question about getting a custom size 1/2" black steel gas pipe (does Home Depot cut custom pipes?????) and the length I am looking for. On both ends are a 90 degree bend so accounting for an inch of thread on each bend, I need a pipe that spans 36 1/2in. My question is what exact measurement pipe do I need to fit into a threaded 90 degree joint on both ends accounting for both the thread on the pipe and the thread in the bend? Hopefully I'm not being too vague........
Thanks for any help!!!!
donshizzles is offline   Reply With Quote
Old 08-09-2009, 07:24 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
If you are measuring center to center of 90 deg then 34 1/2"
I don't think HD cuts and threads pipe. You might call a plumber and ask if they would cut pipe for you.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-09-2009, 09:54 PM   #3
Gus
Home Depot and Lowes both cut and thread pipe. So do some hardware stores.
Gus is offline   Reply With Quote
Old 08-09-2009, 10:41 PM   #4
Registered User
Termite's Avatar
Yup.
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 01:53 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
