Old 04-22-2012, 11:44 PM   #1
custom built shower
I am building a custom shower for my disabled father-in-law. we live in Lafayette La. I am going to have to move the shower control valve from the side of one wall to another wall aboul 6" to a 1'. I was going to use PEC hose system and was wondering if any Plumbers have had any problems with the system. and is there different types. because I have seen crimp and one that pushes in the fitting and locks in.
gbonin is offline   Reply With Quote
Old 04-22-2012, 11:52 PM   #2
custom built shower
If it was mine and you can I'd run 3/4" supplys and use copper to the shower head.
Reason being the 1/2 Pex is slightly smaller on the inside then 1/2 copper.
Old 04-23-2012, 12:10 AM   #3
custom built shower
Thanks. I did not think about the inside ID.
First time custom shower DavidChase Flooring 7 04-30-2011 08:57 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
custom seat behind premade shower pan??? frgwtchr Flooring 13 08-15-2009 11:34 PM
custom shower pan water test -- not draining justheman Kitchen & Bath Remodeling 4 08-03-2009 11:56 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
