Curb Stop Valve Access Cleanout - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-13-2013, 09:51 PM   #1
It turns out the plug to the pipe that leads down to the curb stop valve out in front of my house got busted somehow. Now the pipe is plugged with whatever crud made it's way in there so the valve is inaccessible. The only reason I even knew about it was because the city water guys came by and painted the cap and then sent me a letter telling me to clean out the pipe and replace the cap within 30 days or else they would do it (at a cost).
How do I clean this pipe out? I'm not sure how long the pipe is down to the valve. I shined a flashlight down the pipe and all I could see was standing water about two feet down. I thought I might be able to stick a shop vac hose down there but the pipe is too narrow.
How would a plumber clean this out? Would it be costly?
chilitown is offline   Reply With Quote
Old 05-13-2013, 09:58 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
In my town, that is owned by the water dept. so they fix it- I guess yours is different though.
I'd start by putting a smaller diameter pipe on the shop vac hose somehow- suck the water out and see what you have left.
If the cap was cast iron, I'd get a magnet on a stick or pipe and try to pull the pieces out.
Call the water dept to find a supplier for a new cap
Old 05-14-2013, 09:11 AM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by chilitown View Post
the pipe that leads down to the curb stop...
How large a diameter is the pipe?
How far down in the ground does it go?
If wide enough and shallow enough... a wet vac might be enough.
But I suspect someone is gonna be doing some shoveling soon.
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Replace a shower valve with no access panel ALfromSTL Plumbing 11 12-12-2008 09:56 AM
anti freezing stop and waste valve leaks James Parsons Plumbing 1 10-07-2007 03:11 PM
leaking stop valve farrington135 Plumbing 1 03-31-2007 07:33 PM
