Culligans Water Softener Goes Thru 4 Bags A Week - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-26-2011, 12:48 PM   #1
Culligans Water softener goes thru 4 bags a week
Isn't this too much? 200 lbs a week of salt softner? What can I do?
Larry S is offline   Reply With Quote
Old 06-26-2011, 01:02 PM   #2
Too Short? Cut it Again!
I would call Culligan. Without knowing how much water you are softening I cannot guess as to whether you are using an excessive amount. Timer may be set wrong or something too.
Also, we had terribly hard water in Northern California but I didn't like drinking the softened water. I talk the drinking water lines off the system. It cost a bit more for some plumbing but reduced the load on the softener somewhat. Obviously you do not want to be softening any irrigation lines. Salt and plants do not do well together.
The Following User Says Thank You to user1007 For This Useful Post:
Larry S (06-26-2011)
Old 06-26-2011, 01:15 PM   #3
Makes since
Only 3 of us and we drink bottled water and only use the well water for showers, washing clothes and dishes and an occasional flower watering..I will try Culligans, but they will want to come out and charge for something I may be able to do myself. Thx, Larry S
Old 06-26-2011, 06:55 PM   #4
DIY staff
Rewards Points: 7,174
There is a setting for the amount of salt used per charge---also a clock with settings for days between charges.
Mine is set to recharge every three days--plenty for a family your size.
Look at the controls--re set them---pay Culligan if the controls are O.K.--
There is no reason to be going through that much salt--something is seriously amiss there.
Old 06-27-2011, 09:08 AM   #5
The amount of salt necessary for proper operation is a function of your water quality (hardness, iron, etc) with higher levels requiring more salt, amount of water used, and design choices like size of unit and frequency of regeneration. Without information on all these factors there is no way to know whether your useage is excessive.
That said it certainly sounds high and could be an improperly set up unit or a malfunctioning unit. If you want more help here provide your water analysis, your water usage, and specifications on the softener (cubic feet of resin) as well as the programming (set capacity and salt dose at minimum) but all programming would be better.
Bob999 is offline   Reply With Quote
Old 06-27-2011, 12:06 PM   #6
Rewards Points: 3,130
As mentioned, something is seriously wrong. I live in an area with pretty hard water, and my Culligan unit hardly uses one bag a month.
The Following User Says Thank You to md2lgyk For This Useful Post:
oh'mike (06-27-2011)
Old 07-23-2011, 01:31 PM   #7
seems you need a professional
mr.greenthumb is offline   Reply With Quote
Musty water from water softener tranders Plumbing 49 05-03-2014 02:17 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
What to put under water softener? wiz561 Plumbing 4 12-11-2010 09:37 AM
Pex vs. copper, running a new line to water softener. ams4life Plumbing 9 03-05-2010 05:47 PM
Is this a viable solution for a water softener? imola ghost Plumbing 1 12-23-2008 11:51 PM
