Culligan Water Softener Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2011, 08:47 PM   #1
Culligan water softener problem
I have a Culligan 9" Silver series softener that's not producing soft water. There is a hissing noise coming from the area behind the electronic control panel.
I found that water is running through and going into the drain hose. If I put the unit into bypass the noise and water flow stops. I also cannot get the unit to regenerate while in bypass mode which was suggested to relieve pressure on the unit prior to disassembling. Suggestion appreciated.
Howard
hmsmayda is offline   Reply With Quote
Old 02-01-2011, 09:39 PM   #2
Water Treatment
Rewards Points: 848
Howard
If you put the unit in bypass the water going to the drain will de-pressure the unit in about 5 minutes or so depending on how fast the water is going to the drain while the unit is in the service or home spot.
Akpsdvan is offline   Reply With Quote
Culligan Water softner 1Harley Appliances 2 09-01-2012 04:17 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 02:51 PM
hot water recirculating/sediment confusing problem rcatty Plumbing 1 01-06-2008 04:51 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
