Culligan Water Softener Not Working (pics) - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-13-2011, 04:28 PM   #46
Thanks, that's great, it seems to be working as it should finally.
I did the soap test, and the newly treated water foamed up much more, indicating that softening is taking place, so that's good too. I have somewhere I can take a water sample in for a quantitative test, so I will do that in a day or two.
The only question remaining is to ask why did it happen, and will it happen again? The original problem was resin beads stuck in the drain flow control thingy, as well as quite a lot in the drain pipe itself (an accumulation over some time I expect). And these didn't seem to be broken ones, they were spherical as I found when I put my foot on some that were spilled on the floor and went skidding away. Is it normal for some of these to get expelled from time to time, and if so what sort of preventative maintenance regime is advisable?
As far as the black sulfide is concerned, Culligan's advice is to increase the backwash frequency in the Iron-Cleer water filter, so I will do that and hope that over time the inside of the softener will clean up.
I really appreciate all the help and advice, as without you being there to guide me I would never have got this far. I have also learned a lot about my softener in the process. So a big thank you.
macman44 is offline   Reply With Quote
Old 09-14-2011, 12:29 AM   #47
Water Treatment
Rewards Points: 900
Why did it happen? age, water quality takes a toll on resin..
Will it happen again? most likely ... When ??? any ones guess....
The key now is that if it starts to go south again you know some things to do to correct the challenge when it happens.
Any softener is going to over time brake some of the resin down because of the water and out the drain it goes..
Having the iron filter working at 100% will always be better on the softener so that all that it has to deal with is the hardness..
Having the raw water tested about every other year and the softener reset if needed will help in the long run of the softeners life.
Akpsdvan is offline   Reply With Quote
The Following User Says Thank You to Akpsdvan For This Useful Post:
macman44 (09-14-2011)
Tags
repair , softener
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Culligan Medallist Series water Softener jhunnicutt Appliances 1 01-10-2011 12:52 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
orange water from softener joemontana16 Plumbing 5 11-23-2010 06:34 PM
Water Softener started regenerating when I was changing the water filter nicksergeant Plumbing 0 11-07-2010 06:17 PM
