Culligan Softener Overflows The Brine Tank And Getting Brine Into My House Plumbing. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-03-2012, 08:56 PM   #46
Water Treatment
Rewards Points: 848
You will need to use food grade silicone if you are going to do any new lube on the rubber parts.
It will stand up to the water and not break down and make a mess of things or eat the rubber.
Akpsdvan is offline   Reply With Quote
Old 09-07-2012, 12:07 AM   #47
Found the one o-ring, Still looking for 2 of the other one...
Bookerjdu is offline   Reply With Quote
Old 09-07-2012, 01:08 AM   #48
Water Treatment
Rewards Points: 848
Which o ring did you find and which ones are you still looking for?
Old 09-10-2012, 09:36 PM   #49
I found the one for the brine piston (store here called Princess Auto). I put it all back together including the two other 'bad but not completely broken' o rings on the 'inductor?' part. It is working now and I'm back to having soft water without the tank overflowing or the brine coming through my taps! (big happy face) I'm going to keep looking for the other two o rings as I'm sure before long I will have another problem. However, they are at least easy to get to when I do find them! Thank you for all your help - not sure how you were able to give so much direction without actually being in front of it, but it sure was appreciated!
Old 09-11-2012, 12:08 PM   #50
Water Treatment
Rewards Points: 848
Pleased that you where able to find the o rings and that they worked and your system is up and running again.
