Culligan Rustmaster Controller - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2013, 11:20 PM   #16
Water Treatment
Rewards Points: 816
Davesh, check the message box as I have sent you a pm about the part..
As of today I know that I have at least two that are not on working motors.
Akpsdvan is offline   Reply With Quote
The Following User Says Thank You to Akpsdvan For This Useful Post:
Davesh (02-14-2013)
Old 02-14-2013, 08:02 AM   #17
Akpsdvan,
Since I'm new to the forums I'm not allowed to send PM's yet (15 post minimum for that priviledge). To answer your PM questions...
Yes, the piston moves pretty freely. There is some resistance but it's not stuck. I have to imagine a little resistance is appropriate for the seal? Do you think I should dis-assemble it and clean it? As you might expect I have a lot of iron in my water so anything pre-rustmaster tends to be pretty gunked up. I have some remarkable pics from when I rebuilt the tank.
The white plastic link is cracked pretty badly but still works. I was afraid to try to pull the pin that holds it to the steel shaft for fear of breaking the plastic completely but is that pin just a press/pressure fit?
You can reply directly if you like. Yes, I really want to get one plastic link/cam. Thanks.
Last edited by Davesh; 02-14-2013 at 06:40 PM. Reason: removed my private email address...problem solved
Davesh is offline   Reply With Quote
Tags
rustmaster
What should be VOltage Across 2HP 230V Franklin Pump Controller cb1234 Electrical 10 02-17-2011 12:04 PM
Trailer/truck brake controller problem govman Automotive Repairs 6 10-30-2010 03:46 PM
controller board replacement Turtle learner HVAC 3 12-31-2009 03:00 AM
Help with an ICM271 Controller Card dpbriley HVAC 6 12-20-2009 11:42 PM
Making a blower work with a White Rodgers 50A55-405 Controller gegnerx HVAC 3 01-13-2009 04:58 PM
