My husband hit the manual recharge button to recharge the softener. After about 5 hours of the recharge cycle running on and on (water going outside included), we uplugged the system. It still kept running so we hit the bypass. Today when he turned it back on, it was still running. Is there any way to fix this without calling in the Culligan man? He feels that something is stuck but he just can't find it. Can someone help us?
There are some seals in what is called the seal pack that either have something holding them open or they are bad and the seal pack needs to be replaced.
Now it might be possible to remove the seal pack and take it apart and find the bad one or two and move them to the ends...
The site that has had some packs from time to time does not have any right now so that cheap way of getting a kit is not there.
Where is the seal pack located? I forgot to mention that with all this running it's been doing, the water hasn't been treated. Any help would be greatly appreciated. Thanks!
When one removes the front cover, there are two phillps head screws that hold it on, just to the left of the timer control.
There is the motor and the white cam... behind the white cam there is a screw and then under the motor there are two screws all hold the metal plate to the valve body.
In the middle of that valve body from front to back is the piston and seal pack..
Now if your system is old enough it might not be the seal pack that has gone, but rather the link between the motor and piston that has broken and left the piston where was when the link broke..
OK, he'll try that tomorrow morning and see how that goes. The system is probably around 17-18 years old. He remembered this happened once before but can't remember what the guy did, it was so long ago. I'll have him read this in the morning and see if he can fix it before we have to get out the Culligan Man, which we really can't afford to do at this time. Thank you so much for your help!
There is one more thing that could be.
The motor that moves the piston in and out... could be dead...... or one of the male females connectors could be bad.
Or even the timer motor could have gone bad......
There are about 4 different things that could be the reason that it is dumping water to the drain past the time frame that should be.
OK, I just gave all of your answers to my husband and he said he'll have to check all of this out when he gets home from work tonight. Hopefully it will be something small and he can fix it without having to call anyone in! You have been such a great help, thank you so much!
Sorry I haven't been on - the husband wasn't able to get to this water softener until today. He said everything appears to be moving correctly and was leery to open up the entire thing to see what was going on in there. So, he called Culligan and explained the problem. After playing telephone tag, the Culligan people said that our system was purchased in 1992 and they have no parts but they'd be happy to send out the service guy at $138 for the first half hour to diagnose the problem. We said no thanks! He's going to take the thing apart now since if he screws anything up, they can't replace it anyway, in the hopes that there's just something stuck.
I guess what I'd like to know is if there really are no parts and secondly, what brand of water softener would you recommend if we have to buy a new one? Again, thank you so much for all your help!
There are parts, they just like replacing aged equipment rather than repair.
Good to hear that the motors are still good, that would have been a rather simple fix as all of them are there on the front.
And if the one motor is driving the piston in and then pulling it out either the link or the tray is still good and the piston head is good.
The only other thing that could give "water to the drain while in service" is a seal in the main seal pack/piston assembly.
If one of the o rings is bad or the piston with a grove then it is like a car burning oil.....
I will check in later today to see how it is going.
My husband said "oh, that makes sense". He can't work on it tomorrow but he'll be at it on Saturday so there's no need to check in until Saturday afternoon. He said thank you very much for all the advice. He's going to take the thing apart and hope for the best. He's mechanically inclined but would feel better if there were a manual. Of course, we can't find one online anywhere. I guess it's not a surprise to you since Culligan seems to have quite the monopoly when it comes to their stuff. Thank you!!!!
Try this link out, http://www.culliganwater.com/reside..._softener_and_filter_parts_list_post_1991.pdf
I know that it is not the same valve, but the little secret that they will not tell is that the valve in the link is the same valve that you have, goes on the tank just about the same as yours and the front is a little different, but the seal pack that is in the link is the same as what yours has.........
I really do not like those that make things more than they are... simple....
I will be out for the weekend.... I do use the username in a few other diy sites, and there are a few that would let you private message from the start...
Me again. Hope you had a nice weekend! We have a broken part - part 27 on the diagram that you sent. The piston inside of part 27 appears to be broken from the pushing rod (on top). The O-ring is good. The connection from the steel pushing rod to the plastic is broken and it can't retract that piece. Is there a parts website that we can go on or would a plumbing supply place have it? Hopefully this is it. He turned it on and the water stopped flowing and the recharge switch had resistance. He hit the switch but the water kept on running - no recharge. He thinks this piston thing is the problem. Again, any help would be GREATLY appreciated and thank you again for all your help!
On part number 28, let us call three parts to the whole, there is the cage that has the o rings and spacers, the plastic rings that screw into each other then there is the piston and then the shaft.
If I am understanding what you are talking about, the shaft or shiny metal part that on end hooks into the piston and the other comes out the front to the tray or link... either the piston end is broke and can no longer hold the shaft or the shaft has lost that one end and can no longer hold the piston..
Either way one has two choices, find a full kit or find some one that has re useable parts to rebuild what you have broken and get yours up and running again.
Here's the closest to the problem: piston end is broke and can no longer hold the shaft. My husband said there was a lot of rust buildup and he thinks that's what contributed to the problem. The filter on the top above the piston pack was also clogged with rust/sediment. So, now where does he get the part - Craigs list, Culligan, plumbing supply? After all this, it would stink if he couldn't get the part! Thank you again!
I have no idea if on Craigs list there is some one with the kit that has the seal pack assembly with the brine piston , have seen it a few times on the E, then there are the Culligan dealers, word has it that they have it from 75.00 to 200.00 for the kit..but saddly I have no names of the dealers that have it for the 75.00 other than some place on the upper east coast...
If the screen on that upper assembly is still good it can be cleaned.
If the parts same for the brine assembly can be cleaned still used then finding a used piston that is still good could be a way to go..
That's the part! It's broken on the right side as you're looking at this picture. Where on the upper East Coast? I'm in New Jersey. We have a Culligan dealer in the area, should we see them for the part or won't they sell it to a regular person? So happy we're making progress here! Thanks!
You can check tomorrow if they will sell you that part, I have no idea as to the rules of culligan, or check and see what they want for the kit number 01013033...
Let me know how it goes tomorrow.
Hi. I got your message but I couldn't reply because I don't have 20 posts so I'm racking up the posts here! My husband didn't work from home yesterday so he didn't make any calls. I think he can do it today so I'll keep you posted. I'll have him email or call you to let you know how he makes out. Thanks and have a great day!
Not a problem.
Part of any job is the parts location... finding where the parts are and the time for the parts to get to the job..
At least that is the way it is here in Alaska.. the job might only be about a few hours or a day, but getting the parts.. that is another story.
Still waiting to get the part. The Culligan people are giving my husband the runaround. The piece is in stock but they can't sell it to him unless the Sales/Service Manager himself sells it to him. Only problem with that is the guy is always on the road. My husband has been waiting for a return call since I last posted. Unbelievable. He's ready to just buy a Sears water softener after all this.
I hate sear's but their water softner is a good one. The last one lasted 15 yrs. I bought another one it is still going strong after 6 yrs. I belive the price was around $550.00 with a 1 yrs of free salt. And lot's of good soft water to . I wouldn't mess around with the culligan softner's cost to much. Just paying for the name . my thought.
He's trying to get in with what he took out to show the guy what's broken. The guy won't even call back. They say they sell to the public but you have to catch the guy in. He's going to try tomorrow and he's also going to see if there's another warehouse (?) closer to the area where he's going to be tomorrow. It's so frustrating!
Thanks for the info. We may be looking into the Sears one very soon. Depends on how patient my husband is this week. LOL He doesn't like Sears all that much either but he did hear from someone else that their water softeners are pretty reliable. Our Culligan one is almost 19 years old and we've never had much trouble with it. A part broke, he knows what he needs, now he just needs someone to sell it to him. One of the other nice men on this site helped him to narrow down the problem. We're close, yet so far.
There might be a time to totally replace the unit, but now is not that time, there are still parts out there. There are both new and used parts.
The key is using the information in the pm to get the part or parts needed to get your system back up and running again.
I only have 5 posts to go before I can actually reply to your message (now only 4 after I post this). We may take you up on your offer if we can't get anywhere with these people. I think my husband is going to try somewhere in No. Jersey or on Long Island (NY) when he's out there tomorrow for a meeting. So frustrated! Thanks for the advice on the new vs. fixing this one. He feels the same way and since you narrowed it down, the only thing holding him back is that stupid part! I'll keep you posted and thank you!!!
One reason that I no longer go to the local Ford dealer for any thing on my 7.3 powerstroke is because of run around the trees that they have done in the past... to many times they have told me that they where going to do some thing that never took place..
There is a Bank that is national that I would like to no longer do business with.... but I can not change the mortgage for the house... they too are in the Let us help and then nothing takes place..
Customer service today is no longer what it was years ago..
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
