Culligan Medallist Series 45 Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2010, 09:23 AM   #1
Culligan Medallist Series 45 water softener
I noticed last night the softener was on, didn't think much about it, but this AM when I left for work, it was still on. The display shows an error code, E2. According to the manual, it's a stuck motor. Is this something that I could fix, or should I really call Culligan? The head is about 6-7 years old, the water softener itself is much older, 13+
keithk is offline   Reply With Quote
Old 08-25-2010, 12:50 PM   #2
Water Treatment
Rewards Points: 850
Could be that the piston is stuck, thus holding up the motor, or it is the motor that is stuck.
Depends on how handy you are on fixing items like this softener.
It is out of warranty so no worries there.
Akpsdvan is offline   Reply With Quote
Old 08-25-2010, 01:05 PM   #3
I'm fairly good at tearing into things. I've tried to look at the diagram and part list I have, but the diagram and numbers are very blurry to read.
Old 08-25-2010, 01:29 PM   #4
Water Treatment
Rewards Points: 850
Here is a link to a Fleck 2510, it will give some ideas as to the lay out of your culligan unit.
http://www.pentairwatertreatment.com...al%2040097.pdf
What was the last water test on your well?
Iron, Hardness?
It might be time for a seal pack and piston replacement.
Or a new coat of silicon on the rubber in the seal cage assembly.
Any photo of the unit with the cover off and showing the motor and back plate?
Water Softener Problems Culligan Mark 89 Thespr Plumbing 32 04-01-2016 07:25 PM
Constant Dripping Outside House Valve (Maybe Water Softener) azamsharp Plumbing 5 03-01-2010 07:12 AM
Went to city water - softener still needed? uncleslam General DIY Discussions 5 11-15-2009 05:08 PM
Water softener no longer softening water grandmajo Plumbing 3 01-19-2009 07:42 AM
Water Softener wont stop draining help TTran Plumbing 3 08-24-2008 09:16 PM
