Originally Posted by Akpsdvan
Still have a few.
Think that they are called cam link?
I have not seen one on the bid site that a lot like to use...seen the whole kit, piston cage and the white cam along with the brine piston... but it is a bummer that one often has to buy the large kit just for one plastic part..
i got the part that i needed for $9 at the culligan store locally. but I think the timing on the cam is screwed up it binds when the bell crank (part i got) pin hits the left or right side of the tray that attaches to the seal pack shaft.
I pulled the seal pack (which I replaced a few years ago) and it came out in 2 pieces? the back piece is not attached but does not look broken. I now also have leaks where the by pass valve assembly attaches to the tank.
kind of irritated but think I may just go buy a whole new resin tank a valve assembly and be done with it. I don't have time for this.
