Culligan Mark 89 Stuck On Flush...no Regen.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-19-2013, 12:14 PM   #31
Water Treatment
Rewards Points: 898
If in the brine draw part of the regen cycle there is water coming from the valve , that is wrong it should be trying to pull ones finger in if you put a finger tip on the white fitting there at the valve body.
If the injector is clean it should pull suction.
Reasons again, brine piston in white housing bad, main piston bad?
Or the white cam on top of the motor is stopping early or late for correct line up of brine piston.
Akpsdvan is offline   Reply With Quote
Old 11-20-2013, 09:00 PM   #32
Rewards Points: 29
WERE USING SALT!!!! Just wanted to report back. Thanks for all your help. Can't pinpoint which thing it was maybe combination of all. I mean all rings and parts on new looked and functioned like old , all screens and parts were clean...last thing I did was raise the float about a foot! Figuring it pretty extreme and I should see results and few cycles later and I see big dent in salt and can feel water soft again. Not sure on proper setting for float but will play with it a bit. Thanks again.
yankcrime74 is offline   Reply With Quote
The Following User Says Thank You to yankcrime74 For This Useful Post:
djlandkpl (11-20-2013)
Toilet flush lever problem diyrocks General DIY Discussions 20 12-09-2016 08:12 PM
Water Softener Problems Culligan Mark 89 Thespr Plumbing 32 04-01-2016 06:25 PM
Culligan Aqua-Cleer replacement filters - DIY? liberty79 General DIY Discussions 6 03-04-2012 10:48 AM
Flush Valve Seat sticking to Tank Ball Leah Frances Plumbing 2 05-23-2011 06:53 AM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 07:17 PM
