CSST Tracpipe Wall Box? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2009, 12:37 PM   #1
Rewards Points: 508
CSST Tracpipe wall box?
What's the best way (taking cost into consideration) to terminate tracpipe for a cooktop? The wall boxes are nice, but they're kind of pricey. What would you recommend? I want to minimize the number of fittings I use. Part numbers would be great.
Can you conceive of any way that I could bring the Tracpipe directly out of the wall?
benjamincall is offline   Reply With Quote
Old 05-01-2009, 08:54 AM   #2
Registered User
Termite's Avatar
This is what is normally used for coming up through the floor. They're typically installed in the base of the cabinet or in the floor at the penetrations. I suppose it could be used at a wall, but there are some restrictive protection requirements if you opt for that. The bend radius would also be a big issue. I know that some other CSST manufacturers make wall bends but I'm not seeing one for the TracPipe system.
Here's their installation PDF and it has all the parts they make.
http://www.omegaflex.com/trac/techni..._OmegaFlex.pdf
Old 05-02-2009, 04:39 AM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Yep what thekctermite said....those termination fittings work well. Just throw a threaded valve onto the end then go with your flex connection to the appliance. Also as mentioned, I dont think you'll be able to use that on the wall due to the bend radius either, but there should be space enough on the floor between the wall and the appliance.
JDC is offline   Reply With Quote
Old 06-13-2009, 08:25 PM   #4
Rewards Points: 508
I ended up using the wall box for a nice, clean finish:
http://www.simplyplumbing.com/megafl...-wbtm-750.html
Of course, no one looks at the box under the cabinet.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
CSST gas line through ceiling/floor to appliance pcampbell HVAC 2 05-20-2008 07:36 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
