Cross Threaded Garden Hose - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-30-2012, 12:22 PM   #1
Rewards Points: 12
Cross threaded garden hose
A friend who was helping with watering while I was gone, attached a new hose to my outdoor spigot. He must have cross-threaded it because I cannot remove the hose. Have tried WD 40 and a wrench (but carefully so as not to pinch anything and make it worse). Any ideas on how to remove the hose from the spigot? Any specific tool that might help?
hubbard is offline   Reply With Quote
Old 09-30-2012, 12:46 PM   #2
biggles's Avatar
if the hose female end is even metal and not plastic the brass of the spigot won't cross thread the hose end always goes first..
Old 09-30-2012, 12:58 PM   #3
Too Short? Cut it Again!
It sounds like the only way to get it off is with a wrench so have at it. You will probably have to replace the female fitting if it is stripped. If the male end of the hose bib is brass, as mentioned it should not be damaged.
Old 09-30-2012, 01:40 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 360
Ayuh,.... Channel-lock pliers...
Bondo is online now   Reply With Quote
Old 09-30-2012, 03:21 PM   #5
channel locks as suggested. a pipe wrench will only squeeze it tighter or deform it.
Old 09-30-2012, 08:58 PM   #6
Rewards Points: 582
use channel locks on the solid part of hose connection.....don't use pipe wrench....
Old 10-01-2012, 07:29 AM   #7
Rewards Points: 1,214
After you get it off you can cut the bad end off the hose and put a new female end on it.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 10-01-2012, 08:47 AM   #8
Rewards Points: 12,886
I've had to deal with old washing machine hoses that were frozen in place and used a Dremel tool with the cut off blade to cut the connector in two places being very careful not to cut into the threads.
Once it was cut channel locks broke it free.
Repairing Garden Hose Connection cl6120 Plumbing 9 09-12-2012 10:20 AM
PVC pipe vs Garden Hose ColoradoWildcat Landscaping & Lawn Care 4 08-18-2012 06:37 PM
Pressure washer blew the garden hose tucker0104 Tools 6 05-29-2012 07:51 PM
running extension from outside garden hose faucet denemante Plumbing 6 05-27-2011 01:18 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
