Creaking - Fiberglass Shower Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2012, 04:42 PM   #16
Household Handyman
Rewards Points: 1,408
I have posted many times a true, proven fix for this problem. I have done approximately two dozen shower/tub units that were installed improperly without any base. It's is quite a long post, so do a search for it under my user name. It does involve low expanding foam used to fill garbage bags placed under the tub/shower pan's bottom. This can be done by simply removing the baseboard of a common wall, removing some sheetrock that the baseboad would cover up later. Yes, expanding foam can cause problems if used improperly. You must examine the area and use just enough foam to expand vertically and ooze out some horizontally. This can be done by a DIY person. Good Luck.
The Following User Says Thank You to Thurman For This Useful Post:
ben's plumbing (11-24-2012)
Caulk between wall tile and fiberglass shower pan? LaRae Kitchen & Bath Remodeling 0 01-22-2012 11:37 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
fiberglass as shower membrane achilles Plumbing 1 01-28-2009 09:39 PM
Getting those darn non-slip rubber pads off of bottom of fiberglass shower proofer Plumbing 5 06-15-2008 04:05 PM
Fiberglass creaking sound fburke Plumbing 1 07-02-2005 05:46 AM
