Old 05-24-2007, 10:33 AM   #1
Crazy large noise/vibration when turning on the shower in one of the bath room! Help!
I have one of the bathroom (out of the 2 I have) have this problem: when turning on the shower (above the tub) , a crazy vibrating noise like earth quark happening downstair behind the kitchen walls which is not directly below the bathroom.... this problem seems to not happening if we turn the facet slowly (I mean really really slow).... I heard of somthing like "hammering effect" and I didn't realize it is so noisy... I mean the noise is really really loud and scary.....
Please let me know what is the best way to fix this? .....Thanks a lot......
KUIPORNG is offline   Reply With Quote
Old 05-24-2007, 02:00 PM   #2
I found
http://www.homeandgardensite.com/dcf...rumID15/1.html
looks like this is a common issue... the last message of above link talked about open up the faucet and tightened up one screw ....
I think I will try to do this as it is the most painless solution...
but then if you have anything to say please feel free, such as why tightened up one screw will resolve the issue..etc....
my problem currently stick with only one faucet so that is why I think there may be particular problem with that particular faucet only...
Old 05-24-2007, 02:30 PM   #3
newer than a newbie...
We have a garden hose that works fine when the water is turned on, and there is 'just a hose'.
However, I bought a nice and fancy hose attachment that you can change it to mist, etc...
When i have this hose attachment on, and I turn on the water (not even to the maximum level) there is a loud vibration (rumbling) that my wife complains about.
I think it might have to do with pressure and the sudden pressure causes the pipes to move around vibrating.
I'm not a plumber, but this is a theory.
I have a feeling that if you have a basic, non-energy saving shower head, the vibrations will go away?
It's funny how the Energy Star products seem to have a lot of drawbacks...
What's the point of having a toilet that uses half the water, if you have to flush it 2 times per use? Anyways, just a beef!
Good luck with that.
mcvane is offline   Reply With Quote
Old 05-24-2007, 03:42 PM   #4
Thanks for your insight... now I will try different things... shower head...handle...etc.etc... I hope I don't need to replace the complete set.. as this involves breaking the tiled wall...
anyway... will keep you updated...
Old 05-25-2007, 08:23 AM   #5
I surrender on this one, pay $60 bucks for a professional and got it fixed. It ends up the core of the facuet need to be replaced... I guess I could do that myself. But consider need to shop for the core part, and read the plumbing book carefully, and shutdown the main while going out to get the part...etc.... hiring a pro in this case make a lot of sense.... sometimes... I have to say... you just need to surrender...
Old 05-25-2007, 10:55 AM   #6
I agree with you. For $60, I think you probably just saved a whole lot of personal time and money too.
I had a furnace issue 2 years ago, and although it was a minor fix, I paid a HVAC technician $50, who not only fixed the problem, but was nice to explain things to me. Not only did I not even have to leave my house, but I didn't even need to deal with the research in trying to figure out exactly what the problem was.
I don't know the term, but there was a tube that has moisture run-off and that was clogged with debris...when he blew air through it, the problems were resolved.
Although...when doing a home project (that you can do), you do feel proud that you have done it yourself
Old 05-25-2007, 05:55 PM   #7
...I'm guessing the tub/shower valve is a Symmons, am I right?
http://www.symmons.com/products/res_...y=1&function=1
Ishmael is offline   Reply With Quote
More On This Topic
Sometimes a standard shower head just doesn't do enough. It can't be maneuvered into the right position when someone with a broken arm can't get their cast wet. It can't reach the corners when you clean the tub. It can't rinse all the soap out of Fido's... Read More »
Everyone can benefit from using less energy in their homes. You save money each month on your power bill, plus you have the happy knowledge that you are helping the environment by making your home more energy efficient. If everyone did a few energy... Read More »
Do you put off cleaning those blinds because it's too much of a hassle? You're not alone. I, too, put the chore off for a long time until I discovered an easier, quicker way to tackle this dreaded chore. Follow my step-by-step instructions; and you'll... Read More »
How to Save Energy
How to Save Energy by eHow.com
Saving energy is easy and can save you hundreds of dollars a year. By slightly altering your daily habits, you can save energy without impacting your life at all. Besides the obvious monetary reasons, saving energy is also good for the environment... Read More »
A good hose can be fairly expensive garden equipment. You don't want to have to replace it each time a hole appears. Spotting the hole is usually the easy part, and fixing it doesn't have to be much more difficult. You can repair that hole in the garden... Read More »
Bath room remodel subfloor removal first-timer Carpentry 9 06-21-2007 03:11 PM
Turning a Guest Bedroom into a Master Bath BbAaSsSs Remodeling 18 03-10-2007 06:03 PM
Master Bath Shower Remodel with images MattCoops Remodeling 4 01-10-2007 04:16 PM
Adding a shower to a 1/2 bath amyjean Plumbing 1 09-10-2005 08:06 PM
Help, the bakelite light fitting in my shower room smells! Unregistered Electrical 1 08-13-2004 08:03 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
