Cracked PVC Pool Pipe: Temporary Repair
is the water coming from a main drain at the bottom of the pool?
if so, you could cover the drain with a sheet of heavy gauge plastic film or a rubber mat bigger than the size of the drain. The weight of the water should seal it off, at least temporarily while the pipe is repaired. I'd put a shutoff on there while i was at it. That way you could pressurize the line with air until you see bubbles come up in the pool then shut it off to hold the water back, leaving only (or mostly) air in the line during the winter.
