| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Basement Remodeling: Bathroom Plumbing & Fixtures
by Expert Village
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
Cracked Cylinder Repair: Drain the Coolant
by Expert Village
Drain the coolant using an allan wrench to fit the drain passage to avoid mess during cracked cylinder head repair; learn how in this free auto-restoration video. Read More »
How to Prevent Driveway Potholes
by eHow.com
No matter what type of driveway you have--concrete, asphalt or gravel--you are at risk for developing potholes. Potholes are caused by water penetrating the surface of the driveway. In the case of concrete and asphalt, the water builds up under the... Read More »
How to Repair a Crack in a Concrete Pond
by eHow.com
A sudden loss of water in a concrete pond means there's a crack somewhere. This can be caused by damage from freezing and thawing or by the settling of the ground underneath the pond, or even by an earthquake. If you've got a leak, most often it's... Read More »
Waste Line Needs for New Bathrooms
by Expert Village
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
