-   -   Cracked PVC fitting in concrete (http://www.diychatroom.com/f7/cracked-pvc-fitting-concrete-24359/)
DJupin 07-27-2008 09:50 PM
I was breaking up some concrete in my basement to set a tub. The drain pipe is about 3-4 inches away from another pipe coming out of the concrete that is a vent pipe and also has a T fitting with a cap on it for the rough in for the vanity drain.
After breaking away the concrete for the bath tub draing, I noticed that the fitting for the vent pipe is cracked. I can't see the rest of the fitting just the top but I think that it is inline with the main drain pipe running through the concrete.
How do you repair / replace a fitting that is in concrete? Can I break the concrete away replace the fitting and use rubber fitting with clamps around the drain pipe? My concern is that since the draing pipe is not movable (and assuming that it is 4 inch, which I think the main pipe is) I won't be able to spread it apart to glue in the repair fittings?
Any ideas would be appreciated.
TazinCR 07-28-2008 08:12 AM
A picture would help.
Marlin 07-28-2008 05:39 PM
Yes you can use rubber fittings with clamps. If it really is only a vent you could silicon the crack shut and just never tell anyone what you did.
mstplumber 07-28-2008 10:10 PM
2 Attachment(s)
Technically, you are supposed to use special couplings underground, like this "MG Coupling":
[/IMG]Attachment 4438
I know that some people have sometimes used a no hub band underground with no problem.:whistling2:
No Hub Band:
Attachment 4439
Either one is better than some sort of patch since the line you mention sounds like it will be a drain line.
DJupin 07-29-2008 01:54 PM
Thanks Marlin and mstplumber for your advice.
Lat night I dug more around the cracked pipe fitting and was relieved to discover that it is not a connection into the main drain. The fitting is an elbow connected to a pipe running through the concrete that I assume connects into the main draing down stream a couple of feet. The other end of the elbow is connected to the vertical vent pipe with a Tee that is capped to be used for the vanity drain.
I plan to dig up around the pipe fitting and pipe and then replace the elbow.
So at least I won't need to repair the main drain pipe running through the floor.
Dave Jupin
Termite 07-29-2008 03:26 PM
Oh Marlin, you dissapoint me. :no:
Marlin 07-29-2008 04:12 PM
Can't please everyone :)
