Old 09-03-2012, 10:12 PM   #1
Cracked Housing on Garbage Disposal
I recently moved to a new place that's relatively new overall (only 3 years old) and just noticed today that the garbage disposal is leaking underneath the sink when used. Upon further inspection, there's a slight crack near where the top plastic piece near the bolt that secures to the top and bottom pieces together. I'd hate to have to go out and buy a new one of these for such a small defect when it works fine overall. Could I get away with using some type of silicone seal/caulk for plumbing or maybe even some type of super-glue like resin to fill in the cracks and have it last me a few more years? It's only made of plastic. I'm not even quite sure how it could crack when it's not even in an exposed area of the kitchen. It's an Insinkerator if that makes a difference.
wysiwyg6000 is offline   Reply With Quote
Old 09-03-2012, 10:18 PM   #2
Super Moderator
Sorry,but the inside is like a tin can--when it splits it's junk.
They have a warranty by I doubt that anyone keeps the warranty info---time for a new one---
Old 09-03-2012, 10:26 PM   #3
call me E
TheEplumber's Avatar
I agree, too much tork and vibration. Nothing will seal it.
Old 09-04-2012, 10:57 AM   #4
you could try epoxy or on of the steel epoxies. when you replace it get an insinkerator with the stainless steel grind chamber and this wont happen again. sounds like it is a badger which is their bottom end disposal and made mostly of pot metal.
Old 09-04-2012, 11:06 AM   #5
Have you made contact with the company to ask them about the problum.
If yours cracked I'm sure it's not the first time and they may offer you something for your trouble.
It's free to ask.
Old 09-04-2012, 09:56 PM   #6
As luck would have it, it has a 2 year warranty and it's been installed for roughly 3 . So I doubt they'll be honoring anything at this point. It is a Badger 5 model and a quick Google search reveals that a lot of other people are having this problem too. Honestly, I don't even use the disposal feature since I never flush solid food down there. It just leaks now when I dump water down the drain that I would like to stop. I can replace it when it's time to move in a few years. Could I use pipe dope to cover the cracks with and form a seal?
Old 09-04-2012, 10:05 PM   #7
listen ...to what is being said....if cracked its junk....badger 5 at lowes or hardware..75.00...simple install....ben sr
Old 09-04-2012, 10:32 PM   #8
call me E
You could always replace the disposal with a standard basket strainer and continuous waste piping. Set you back about $20 or so vs. a new badger...
Just don't try to patch it- waste of your time- wysiwyg
switch to garbage disposal question tard01 Electrical 64 03-30-2012 06:19 PM
Double dishwasher, dble sink garbage disposal dilemma pettychat Plumbing 2 01-12-2012 04:43 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 11:03 PM
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 04:00 PM
