Cracked Hose Bibb, No Interior Access - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2010, 10:25 PM   #1
I have an exterior hose bibb that has a crack in the threads where the valve stem screws into the body. It leaks from this joint. I "repaired" it about a year ago by using plumber's tape, but now it is leaking again. There is no interior access to the back of the hose bibb without ripping-up a wall. Does anybody have an idea as to to get this hose bibb to stop leaking?
Roxbury is offline   Reply With Quote
Old 05-03-2010, 07:06 AM   #2
DIY staff
Rewards Points: 7,174
You are out of luck!!! Any thing can be done of course--brazing and retapping the hole--
However--that's not practical.--Get your self a new frost proof hose bib--and a shut off for the line and open the plaster.---Mike---
Old 05-03-2010, 07:18 AM   #3
Rewards Points: 1,214
I second o'mike.
COLDIRON is offline   Reply With Quote
Old 05-03-2010, 09:00 AM   #4
Rewards Points: 190
I would take out the two screws holding the flange of the valve. Go into the basement and loosen the pipe straps holding the pipe feeding the valve. You might get lucky and be able to pull the valve out enough to cut it off and attach a new one without breaking the wall.
zircon is offline   Reply With Quote
Old 05-03-2010, 10:02 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
That doesn't look like a frost-proof to me.
It should be a simple fix really. If you take the screws out there should be movement in the piping, IE : if you pull on it, it should pull away from the wall 2-3 inches. That will give you access to the male pipe thread adapter behind it. Hold onto the MPT adapter and unscrew the hose-bibb. Reverse process to install a new one. P.S. put some vice grips or something very gently on the pipe behind the MPT adapter if possible to prevent it from sucking into the wall after you pull off the old hose-bibb.
Journeyman Plumber
Strange faucet (hose bibb) pjpjpjpj Plumbing 7 08-24-2009 08:12 AM
Hose Bibb Replacement newbs Plumbing 9 04-13-2009 01:27 AM
Hose Bibb replacement MarkRollins Plumbing 2 07-02-2007 06:33 PM
replacing hose bibb leroyme Plumbing 23 04-16-2007 06:45 PM
Pipe size for hose bibb BigJimmy Plumbing 1 03-12-2007 02:53 PM
