Cpvc Threaded Washer Inlet Valve To Threaded Cpvc - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-25-2012, 09:53 AM   #1
cpvc threaded washer inlet valve to threaded cpvc
Do plumbing installers use a catalytic type agent when installing Oatey valves or can they be unscrewed to replace with a new valve #38969.
Second request, please help
arthur norek is offline   Reply With Quote
Old 01-25-2012, 11:28 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 806
Care to elaborate some? Valves are screwed or glued into position.
Old 01-25-2012, 04:05 PM   #3
the inlet valve is threaded cpvc. I cannot see the connection below the valve box. I am told it is also cpvc. My question is: can the present valve be simply unscrewed without damage. Or do plumbers use a sealant which would break if I try to unscrew it.
Old 01-25-2012, 08:57 PM   #4
This is what the valve looks like that you are trying to remove. It's usually installed with teflon tape & pipe dope so there shouldn't be a problem with the valve. (C)PVC does not normally age well & can be brittle so be careful when undoing the connection. Use crescent wrenches only, holding the CPVC firmly & unscrewing at the valve.
VIPlumber is offline   Reply With Quote
Old 01-25-2012, 11:03 PM   #5
Rewards Points: 582
I would not try to remove that without backing up the other fitting..asking for trouble... is that in a washer box???
Old 01-26-2012, 02:13 PM   #6
Thank you for responding. Yes it is in an Oatey box containing hot on left, cold on right and drain to far right. The cpvc threaded female is below the bottom of the box and behind wallboard. I cannot see it or figure how to grip it without cutting into the wall. Is that what is required? Wow. Is it not safe to try to turn it out just above the box?
Again, thanks so much for your response.
Art
Old 01-26-2012, 07:30 PM   #7
Rewards Points: 582
Art
wow is right..had 2-that my guys did like yours on cpvc..both broke the pipe because no support....
Old 01-27-2012, 05:53 AM   #8
Ben:
Thank you so much. Seems this is more than I bargained for as a do it yourself job.
Best to you,
Art
Old 01-27-2012, 07:43 PM   #9
Rewards Points: 582
Ben:
Best to you,
Art
best to you as well ..sorry for the bad news...ben
oatey threaded washer inlet valve cpvc to cpvc arthur norek Plumbing 0 01-24-2012 10:23 AM
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 08:38 PM
Threaded shower valve connection NailedIt Plumbing 1 07-11-2009 10:06 PM
Sweating the threaded end into a shower valve dab3ar$ Plumbing 5 04-11-2009 08:41 AM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 08:19 AM
