CPVC (or Pex) + Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2012, 11:56 AM   #1
MarginallyQualified
Rewards Points: 2,464
CPVC (or pex) + pressure
I have an idea to set up a 3/4" pipe exclusively for exterior uses.
Mostly through the hose bibs but other sprinklers, irrigation and such...
and then another regulator and 3/4" copper for the other uses at 50PSI
The question/concern I have is about the static pressure strength of pipe choices.
According to the city I might have as much as 110 PSI before the regulator.
(At present there is 70PSI after the regulator)
As I really don't want to have a flood in my soon to be finished basement...
I'm figuring it's a good idea to ask how high I can go before risk of failure.
Anyone know?
Old 04-04-2012, 12:05 PM   #2
Homerepairguy's Avatar
Rewards Points: 998
Anyone know?
Regarding PEX, the Uponor installation guide for PEX states 40-60 psi working pressure, 100 psi max pressure while testing for leaks.
HRG
Homerepairguy is offline   Reply With Quote
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
Hydronic boiler pressure question. RickInMissouri HVAC 1 01-23-2010 04:57 AM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 07:48 PM
pressure tank problem? steel Plumbing 14 07-03-2008 02:06 PM
