Cpvc To Pex - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2012, 07:49 PM   #1
Cpvc to pex
Been having problems with leaks at fitting and couplings on CPCV. Had the plumbers here first they dry fired my new water heater then after they came back fixed that one of there fittings sprung a leak. I f I would change to pex what type of fittings would i need to hook the pex into the cpvc
dakota11 is offline   Reply With Quote
Old 02-14-2012, 09:07 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
You can use a shark bite or gator bite connector.
You can get them at any big box store
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-15-2012, 08:33 PM   #3
Rewards Points: 582
can you get rid of all the cpvc????and go to all pex... if not try shark bite fittings at lowes and home depot..
Water Heater Connections (CPVC) Pittsville Plumbing 16 01-21-2012 08:02 AM
Copper vs. CPVC mykquin Plumbing 32 11-17-2011 02:42 PM
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 08:38 PM
Connecting Water Filter Housing to CPVC Pittsville Plumbing 7 01-20-2011 02:01 PM
CPVC tubing and angle stop valve Wiscbldr Building & Construction 1 01-14-2011 10:11 AM
