CPVC Mistake - Advice Apprecaited - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2013, 10:45 PM   #1
CPVC mistake - advice apprecaited
I had to replace a segment of CPVC with PEX. The 1/2" PEX to 1/2" CPVC adapter should have been primed, then cemented to the CPVC (nothing new here).
I primed the CPVC but did not put cement on. I let it dry for a few hours and completed the installation. There are no leaks as of 3 days later and everything works perfectly.
Should I reinstall? I've heard that the primer's job is to bond the pipes together - and it appears that this has been done. Advice appreciated.
fairpriceticket is offline   Reply With Quote
Old 03-20-2013, 12:07 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Re-do it.
The primer is a cleaner/softener. It doesn't bond the pipe by itself or else we wouldn't need the glue.
Journeyman Plumber
Old 03-20-2013, 01:18 AM   #3
Always learning...
fetzer85's Avatar
Rewards Points: 262
Next time you're in the plumbing isle pick up some Flowguard Gold. It's a one step CPVC cement so it doesn't require any primer. I used it on my last project and it was great. Any time I can cut a step out you can count me in!
fetzer85 is offline   Reply With Quote
The Following User Says Thank You to fetzer85 For This Useful Post:
64pvolvo1800 (03-20-2013)
Old 03-20-2013, 02:23 AM   #4
thanks guys, going to just get rid of the CPVC altogether and go all pex now - would have saved me time if I had done that in the first place.
Tags
cement , cpvc , primer
Need advice on plumbing for new washer AliceT24 Plumbing 9 02-17-2011 11:43 AM
Advice is not always correct! Docwhitley Plumbing 9 02-14-2011 10:12 PM
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 07:08 PM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 09:40 AM
