-   -   CPVC mistake - advice apprecaited (http://www.diychatroom.com/f7/cpvc-mistake-advice-apprecaited-174983/)
fairpriceticket 03-19-2013 10:45 PM
I had to replace a segment of CPVC with PEX. The 1/2" PEX to 1/2" CPVC adapter should have been primed, then cemented to the CPVC (nothing new here).
I primed the CPVC but did not put cement on. I let it dry for a few hours and completed the installation. There are no leaks as of 3 days later and everything works perfectly.
Should I reinstall? I've heard that the primer's job is to bond the pipes together - and it appears that this has been done. Advice appreciated.
Alan 03-20-2013 12:07 AM
Re-do it.
The primer is a cleaner/softener. It doesn't bond the pipe by itself or else we wouldn't need the glue. :whistling2:
fetzer85 03-20-2013 01:18 AM
Next time you're in the plumbing isle pick up some Flowguard Gold. It's a one step CPVC cement so it doesn't require any primer. I used it on my last project and it was great. Any time I can cut a step out you can count me in! :thumbup:
fairpriceticket 03-20-2013 02:23 AM
thanks guys, going to just get rid of the CPVC altogether and go all pex now - would have saved me time if I had done that in the first place.
