Cpvc Female Adapter W/ O-ring - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2012, 06:40 PM   #1
Cpvc female adapter w/ o-ring
I'm in the middle of redoing my guest bath and am into the plumbing. I have installed a new shower valve with 4 male 1/2" pipe outlets (hot, cold, shower, bath). To plumb in the hot and cold I used cpvc female adapters with the o-rings. When I tighten them down as snug as I would expect it I appear to bulge the o-ring. It is leak free but i worry about the flow (takes roughly 8 to 10 seconds to fill a gallon bucket). Are these o-rings supposed to bulge? Does my flow sound restricted?
Thanks in advance for any and all help.
Chris
crza1 is offline   Reply With Quote
Old 02-15-2012, 06:47 PM   #2
Rewards Points: 13,458
I've never heard of CPVC fittings with O rings, how about a picture.
Should have been glued fittings.
Old 02-15-2012, 07:12 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
I think what you are talking about is there is a bib washer in the female adapter.
First off all you DO NOT want to make a connection like this inside a wall. It needs to be a solid connection.
Either a sweated joint, a shark bite connector but not what you are wanting to do.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-15-2012, 07:26 PM   #4
I am planing to use this to make the valve to cpvc connection http://www.google.com/imgres?um=1&hl...t:429,r:18,s:0
Miketx is offline   Reply With Quote
Old 02-15-2012, 07:45 PM   #5
Rewards Points: 560
Originally Posted by Miketx View Post
I am plan to use this to make the valve to cpvc connection http://www.google.com/imgres?um=1&hl...t:429,r:18,s:0
Start your own post and you may get answers.
Old 02-15-2012, 08:28 PM   #6
Rewards Points: 582
I have seen this at hardware stores cpvc male adapter with o ring on female part....as mentioned you do not want to make this connection in the wall either solder fittings or shark bite ...I would not trust those fittings...
Old 02-15-2012, 09:02 PM   #7
Here is what I used...
http://www.homedepot.com/h_d1/N-5yc1...kuId=202904742
I saw the other female adapter version (linked above) and in fact used the other version on my kitchen remodel. Not really sure why I grabbed what I did?
Is the one in my link not code for behind wall or is that more a personal sentiment?
Old 02-15-2012, 09:09 PM   #8
Rewards Points: 560
The one linked above will be better than the one you have.
Old 02-16-2012, 09:18 AM   #9
Rewards Points: 3,130
I don't think PVC/CPVC female adapters are code legal. In any case, I sould never use one inside a wall.
Old 02-16-2012, 09:39 AM   #10
I've had that style fitting crack in half before. Get rid of it.
Old 02-16-2012, 01:08 PM   #11
I'm pretty sure that's why they're illegal.
Old 02-16-2012, 01:11 PM   #12
Threw me off when the OP said o ring, it's a flat washer.
Old 02-16-2012, 05:28 PM   #13
Correct, it's a flat washer not an o-ring. Think I'll go the shark bite route.
Modifying laptop ac adapter - Confused. miller108 Electrical 7 01-14-2013 08:49 AM
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 08:38 PM
Connecting Water Filter Housing to CPVC Pittsville Plumbing 7 01-20-2011 02:01 PM
closet ring flange help/explaination eyeglass Plumbing 2 09-09-2009 06:35 PM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 10:12 AM
