-   -   Cpvc female adapter w/ o-ring (http://www.diychatroom.com/f7/cpvc-female-adapter-w-o-ring-133875/)
crza1 02-15-2012 06:40 PM
I'm in the middle of redoing my guest bath and am into the plumbing. I have installed a new shower valve with 4 male 1/2" pipe outlets (hot, cold, shower, bath). To plumb in the hot and cold I used cpvc female adapters with the o-rings. When I tighten them down as snug as I would expect it I appear to bulge the o-ring. It is leak free but i worry about the flow (takes roughly 8 to 10 seconds to fill a gallon bucket). Are these o-rings supposed to bulge? Does my flow sound restricted?
Thanks in advance for any and all help.
Chris
joecaption 02-15-2012 06:47 PM
I've never heard of CPVC fittings with O rings, how about a picture.
Should have been glued fittings.
Plumber101 02-15-2012 07:12 PM
I think what you are talking about is there is a bib washer in the female adapter.
First off all you DO NOT want to make a connection like this inside a wall. It needs to be a solid connection.
Either a sweated joint, a shark bite connector but not what you are wanting to do.
Miketx 02-15-2012 07:26 PM
I am planing to use this to make the valve to cpvc connection http://www.google.com/imgres?um=1&hl...t:429,r:18,s:0
Plumber101 02-15-2012 07:45 PM
Originally Posted by Miketx (Post 854545)
I am plan to use this to make the valve to cpvc connection http://www.google.com/imgres?um=1&hl...t:429,r:18,s:0
Start your own post and you may get answers.
ben's plumbing 02-15-2012 08:28 PM
I have seen this at hardware stores cpvc male adapter with o ring on female part....as mentioned you do not want to make this connection in the wall either solder fittings or shark bite ...I would not trust those fittings...
crza1 02-15-2012 09:02 PM
Here is what I used...
http://www.homedepot.com/h_d1/N-5yc1...kuId=202904742
I saw the other female adapter version (linked above) and in fact used the other version on my kitchen remodel. Not really sure why I grabbed what I did?
Is the one in my link not code for behind wall or is that more a personal sentiment?
Plumber101 02-15-2012 09:09 PM
The one linked above will be better than the one you have.
md2lgyk 02-16-2012 09:18 AM
I don't think PVC/CPVC female adapters are code legal. In any case, I sould never use one inside a wall.
joecaption 02-16-2012 09:39 AM
I've had that style fitting crack in half before. Get rid of it.
md2lgyk 02-16-2012 01:08 PM
I'm pretty sure that's why they're illegal.
joecaption 02-16-2012 01:11 PM
Threw me off when the OP said o ring, it's a flat washer.
crza1 02-16-2012 05:28 PM
Correct, it's a flat washer not an o-ring. Think I'll go the shark bite route.
