CPVC Female Adapter - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-13-2013, 08:38 PM   #1
cPVC Female Adapter
Hey all.
After the shower handle blew out of my bathroom for the last time I decided it was time to replace the assembly with an all in one. In the midst of removing the old unit the copper piping from the diverter to shower head sprang a leak. Rather than fussing with repairing the leak I opted to replace the 4 foot section is some CPVP to make it easier on myself.
Here is the problem. The female to 1/2 inch adapter from the diverter was leaking after I turned the water back on. This was from me not tightening it up enough (doh.) After removing it to reapply my tape I noticed that the washer had fallen out and into the assembly. It wasn't a big deal as I was able to pick it right out.
Do you think I can put this back together without the washer? It seems as if the tighter I get the adapter the washer is forced out into the pipe, if that makes sense.
I would just hook it back up and try it out, but I want to try and avoid buying anymore parts haha. Once that glue sets up your out of luck.
The black washer inside is working itself into the pipe when I tighten it up
Michaelpro is offline   Reply With Quote
Old 06-13-2013, 08:51 PM   #2
Rewards Points: 358
try it again, use both pipe dope and tape. Put pipe dope on threads first, then wrap your tape on. Make sure tape is going right direction as you screw it together (CW). Shouldn't have to turn it too tight. Overtightening is just as bad. See what happens. Because like you said, once you glue it, your done and must start over again.
jmon is online now   Reply With Quote
Old 06-13-2013, 08:52 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 922
You'd be better off using this one- it's designed to transition iron pipe threads to plastic. Your type may crack in the future
http://www.homedepot.com/p/NIBCO-1-2...2#.Ubp28Odwotg
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Javiles (06-15-2013), jmon (06-13-2013)
Old 06-13-2013, 09:15 PM   #4
Rewards Points: 358
IMO, much better. Doesn't look like any washer to worry about either.
Old 06-13-2013, 09:19 PM   #5
Plumber
Rewards Points: 922
The problem with female adapters that are all plastic is that they'll crack more times than not. And it doesn't happen until the wall is finished or the ditch is backfilled.
JDC (06-13-2013), jmon (06-13-2013)
Old 06-13-2013, 09:23 PM   #6
I love the look of that, but it isn't available at the plumbing place in my town.
Old 06-13-2013, 09:23 PM   #7
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Absolutely! I wont use an all plastic female adapter....male either for that matter.
JDC is offline   Reply With Quote
The Following User Says Thank You to JDC For This Useful Post:
jmon (06-13-2013)
Old 06-14-2013, 04:32 AM   #8
Rewards Points: 14,312
I'd use one of these.
http://www.sharkbiteplumbing.com/sha...drop-ear-elbow
jmon (06-14-2013)
Modifying laptop ac adapter - Confused. miller108 Electrical 7 01-14-2013 08:49 AM
PVC or CPVC pipe cement steve3847 Plumbing 7 11-17-2012 05:50 PM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 06:16 AM
Cpvc female adapter w/ o-ring crza1 Plumbing 12 02-16-2012 05:28 PM
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 08:38 PM
